Encap Juice preference
Danbo
South Carolina
Dan Moore
Haven't seen it asked for a while, just wanted to see everyone's input on what your overall favorite Encap Juice is?
D Luke
MI
Derek
Encapuclean DS with Maxim has given me absolutely no reason to try anything else.
Reactions: J Scott W
D Luke
MI
Derek
The price is very low compared to some of the others?
Probably a reason for that. I never skimp on Encapuclean because your costs are so darn low to begin with, might as well buy the best.
Guys. I used the new Hoss encap juice today and was not at all happy with it. The stuff clogged up my Orbot. It had turned chunky with thin little flakes of floaters. I was running my vibe with my hands down the tank, wiping the suck screen with my finger. I won't be using that stuff any more. To bad too, it smells like coca-cola.
Reactions: RCC-AZ and Danbo
SteamwayPro
USA
George
Buy from Vacaway Excellent Supply or Bonnet Pro and you can't go wrong. They all have excellent encaps that work. If you are doing straight encap make sure you buy a crystallizer and not a film forming encap. Bonnet Pro does not sell crystallizers only film forming encaps.
kevinj6121
Calabash, NC
kevin
Guys. I used the new Hoss encap juice today and was not at all happy with it. The stuff clogged up my Orbot. It had turned chunky with thin little flakes of floaters. I was running my vibe with my hands down the tank, wiping the suck screen with my finger. I won't be using that stuff any more. To bad too, it spells like coca-cola.
I've used the Environ encap chem from orbot that i got when i bought my Vibe, they gave me a whole case, i've used it in the vibe and a couple of times in my 175 that has a solution tank and i used the carpet brush, the product works pretty good in my opinion and i've had no clogging issue at all when used in the vibe, always shake your chems before using them.
I also always flush out my vibe after every use at end of day, i put fresh hot tap water in the tank and run the sprayer to get out all the encap juice, i do this no matter who's encap juice i use.
Reactions: Old Coastie
Give it a month
I did about a 6000 sqft job on Friday with my Sprayborg using Bridgepoints Encapuclean o2. Seems like it did a nice job, no clogging and took out some coffee stains and cleaned up the lunch room nicely.
