Sutorbilt 3M shaft wiped
carpetcleaner
Gilbert, AZ
Rob Litwin
It looks like the keyway somehow broke and wiped out the shaft on the blower. Can the shaft be replaced? There aren't many hours on this blower, so I would like to fix it.
The same thing happened to a different TM years ago. There were over 4 thousand hours on it, so I just replaced the blower.
can't answer whether replacement is cost effective or not....
but curious, did the shaft keyway channel actually chip/break?
Or the shaft got scored up from a sheared key?
..L.T.A
Village Idiot
I know it can be replaced. Years ago I knocked the shaft out of a lobe of a 4mp for someone here on the forum but for the life of me I can't remember who it was. I seem to remember it ended up being different than the one he needed.
Finding one would probably be the biggest issue unless you have an old blower laying around.
Seems like it would be more of a pita than it is worth.
Onfire_02_01
Minnesota
Jeremy Gray
Yes you can, but check with local dealers as a brand new one may not be all that much more than all the parts and all the labor.
3 pieces I am impressed! Can we get a picture? You could sell it as mechanic porn.
Grand Rapids, MN
A lot of places are finding it just best to replace....
Not much more money by the time a person is done vs just buying new....sadly to say....
$300 plus shipping and it's yours
dgardner
Phoenix, AZ
Dan Gardner
I'm pulling the blower off to see if a welder can fix it
Is this in working condition?
Yes, buy the one from Steve.
While the shaft can most likely be repaired by welding, it would require disassembly of the blower. For one thing, welding in place would wreck the seals from the heat, and the shaft also needs to be turned on a lathe to true it up once welded, and then set up on a mill to recut the keyway. Here is a video that shows the work needed (on a much larger shaft):
If you get a replacement blower, and can find someone to disassemble and reassemble the old blower (I don't have the special tools needed), I would be happy to give the shaft repair a whirl. I have a lathe, mill to recut the keyway, and TIG welder. would do it for free, just as an interesting project, as long as you aren't in a huge hurry. But I think even if I do the shaft repair for free the cost to disassemble and reassemble the blower (setting the timing and clearances, new seals, etc. might be cost prohibitive just to have a spare blower on the shelf.
If you're in Gilbert then I'm just a little ways away in Phoenix.
BTW, you should try to figure out the reason for the failure before sacrificing another blower. One thing that can be an issue is excessive overhung load on the shaft caused by positioning the sheave (pulley) too far outboard. The Sutorbilt manual calls for the sheave to be no further away from the blower case than 0.38" (about 3/8"). If the sheave is way out there coupled with excessive belt tension, you can end up with a broken shaft.
