The white magic 1200 direct drive. Spill The beans! What do you know about it?
White Magic uses a separate belt just for the machine. Driven off a pulley attached to the front crankcase pulley.
Want to buy a worn out 2002? I already had to pull the solution line off it for the butler. Not sure if I'll keep it going or not but I will be buying new solution line fotthe butler and put the other back on the WM.
