2008 Butler System RPM and speed control issues
Discussion in 'The Hardware' started by Andrew from Simply Clean, Apr 25, 2018.
  1. Matt Wood
    Matt Wood
    4,331
    Georgia
    Name:
    matt wood
    I’m thinking about getting a close up look today
  2. Desk Jockey
    Jimi
    56,060
    a planet far far away
    Name:
    Mr Misunderstood
    It looked solid, just dated.
    Heat from secondary fuel, high pressure pump, blower...diamond plate and an oil barrel. :shifty:
    Matt Wood likes this.
  3. Mark Saiger
    9,409
    Grand Rapids, MN
    Name:
    2 air cooled Motors... And wait for it....
    2 barrels!
    Set at 20 hg :smile:
    Justin Stockwell likes this.
  4. Desk Jockey
    Jimi
    56,060
    Name:
    Mr Misunderstood
    :biggrin:
  5. Cleanworks
    8,085
    Name:
    Just what every cleaner needs. A double barreled truckmount
  6. Andrew from Simply Clean
    Apr 25, 2018
    30
    Manitowoc, WI
    Name:
    Andrew
    :yawn: Lol
  7. Andrew from Simply Clean
    Apr 25, 2018
    30
    Manitowoc, WI
    Name:
    Andrew
    Problem solved! There is a T shaped connector that splits the windshield washer style tubing from the blower and plugs into the back of the vacuum gauge as well as the vacuum switch for controlling operation speed (RPM) and mine was unplugged! A simple fix that didn't cost me anything! The Rpms held perfectly on just the right setting all day :biggrin: 20180429_201437.png 20180429_195727.png
  8. Cherokee
    Cherokee
    Mar 8, 2015
    60
    Cherokee Village, Arkansas
    Name:
    Matt Middleton
    There is nothing like looking when you want to find something.
    Happy that you got it fixed!
  9. Desk Jockey
    Jimi
    56,060
    Name:
    Mr Misunderstood
    I need to check ours and see if it's is connected.
  10. Andrew from Simply Clean
    Apr 25, 2018
    30
    Manitowoc, WI
    Name:
    Andrew
    Also Sometimes the small tubing can have a leak or be clogged it's only like 5 bucks to replace it if necessary. Good luck!
    Mikey P likes this.
  11. Doug Cox
    Doug Cox
    Dec 17, 2006
    4,237
    Delavan, WI
    Name:
    Doug Cox
    That is the saddest statement I heard about a company in a while. Come to think of it, I'm wrong. It was just a month or so ago when Mark was dealing with his van. Hmmmm?
  12. Andrew from Simply Clean
    Apr 25, 2018
    30
    Manitowoc, WI
    Name:
    Andrew
    Butler makes a good machine my only complaint is the prices for parts are really high and sometimes customer service in my experience isn't the greatest. I solved the problem on my own. Why couldn't they mention the tubing? Idk :dejection:
    Cleanworks likes this.
Share This Page
