5.3 million dollar suite
Clean carpets in a suite worth $5.3 million. They have the cheapest polyester carpets and cheap laminate floors. Go figure.
Bc
Jeff T
I see you busted out the GOOD wand for them Ron......(AW 29)...
Gotta pick your brain sometime about your custom porty.... I FOOKIN hate mine....
Reactions: Bob Pruitt
Bc
Jeff T
Cheap isn't based on finances it's a state of mind
When I was in construction, there was a guy who drove an old Dodge pick up. He wore a cowboy hat, and plaid shirt. To look at him, you would think he was just a regular Joe. As it turns out, he owned half of the downtown waterfront. He was worth probably 3-400 million. He was known for being cheap beyond belief. Guess that’s what it takes to get to that point....
FB7777
Nothing about that place says $5.3 million
No Crown moulding and cheap baseboards
Looks like a sOOperhero section8 fixer upper
Actually today I am using a modified speedster. Rewired for 2 power cords. It's good for small jobs like this. The speedster is a nice design but they screw up the components for Canadians. They always require a 20 amp circuit. This one has 2-9.8 amp 3 stage vacs in parallel. 2 inch plumbing. Vacuum is not bad but I will be upgrading to the 13.5 amp ones. The pump is a 200 psi Pumptec, not very good. I have a 500 psi 1/2 HP one that I will install. Should be a powerful little machine. My big machine is more for larger jobs.
Bc
Jeff T
In Vancouver, a house built in 1944, in the right neighbourhood, could probably fetch that price.... WAY overpriced.....
Bc
Jeff T
Years ago, my parents bought a lakefront property for 49k. I was 11 years old. When my father past away in 2010, my mom started to liquidate what they had accumulated over the years. She sold it in the fall of 2011, for 1.3 mil.... the taxes on the property( no house on it), were 18,000 in 2011....
not far off
'cept we don't whitewash molding, doors and walls all same color
Too, the doors we install aren't flat...they're 6 panel Masonite......
and only two options available for vinyl replacement windows ....cheap and cheaper
I have been able to talk some of them into a commercial grade LVT as the better value overall though
Holds up better than the cheap snap/crap laminate and sheet vinyl they like to spec
..LT.A.
Reactions: FB7777
FB7777
Not disputing the view it's great
Serious mismatch in the interior decor
Built in wal units , molding and high quality materials would dress it up nicely
