Acid rinse directly into fresh water tank?
Discussion in 'the CleAn Room' started by Jeremy Martin, May 12, 2018.
  1. Jimmy L
    10,778
    Name:
    I use my own urine in the water tank it's highly acidic.
    dealtimeman, Mikey P and SamIam like this.
  2. rider0992
    rider0992
    425
    Red State
    Name:
    Drowns out cat urine!!
  3. SamIam
    7,350
    Name:
    if the manufacturer say X and your using a water softener cut it in half!
    Also how big is your fresh water tank?
  4. SamIam
    7,350
    Name:
    That’s why your always pissed off!
    Lint Basket and rider0992 like this.
  5. Papa John
    2,654
    San Francisco, CA.
    Name:
    Alkaline cleaners leave deposits inside the plumbing of the heat exchangers, reducing their efficiency and even clogging them in severe cases.
    Running an acid through the system will clean out those deposits.
    Matt Wood likes this.
  6. hydracat
    hydracat
    Aug 14, 2012
    158
    olympia wa
    I haven't had a chem injector in years. Never had a problem. It can leave fuzzy looking stuff in the bottom of the tank. Probably fillers or stabilizers of some sort. Using flex ice for a while now.
  7. Cleanworks
    8,096
    Name:
    Acid cleaners do the same thing. Has nothing to do with acid or alkaline. Has to do with the make up of the product. Vinegar or descaling products clean out your system because they have no soap or detergent products or fillers. Acid cleaners leave as much residue as alkaline cleaners.
  8. icleancarpetz
    icleancarpetz
    Mar 7, 2015
    326
    19734
    Name:
    Rafael Samson
    I’d say about 16 oz for 75 gal
    I made the mistake of dumping into 75 gal tank half gal to a gal using all fiber rinse from JonDon. Stuff ok but foams up. Lesson learned. So now if a had to it, 16 ounces is the sweet spot for me.
  9. scottw
    scottw
    Oct 16, 2006
    2,642
    West Jordan, UT
    Name:
    Scott Warrington
    Most rinse products should be diluted at either 1:320 or 1 :640. Use 1:640 if you have soft water. 1:320 if you have hard water. Somewhere in between is OK for most.
    100 gallon fresh water tank would need somewhere between 20 and 40 ounces. A quart would be a nice round amount.
    Lint Basket and SamIam like this.
  10. steve_64
    6,996
    I would run an emulsifier for my rinse if I had to dump it right in the tank. Just dilute it a lot. Wayyy cheaper and easier on the parts.
  11. scottw
    scottw
    Oct 16, 2006
    2,642
    West Jordan, UT
    Name:
    Scott Warrington
    At 1:640 whatever you put in your rinse is going to be pretty inexpensive. An acid side rinse helps keeps down (or eliminates) the build-up of scale in your plumbing.
    steve_64 and Matt Wood like this.
Share This Page
