Any ol' vct atripper going to remove this?
Hack Attack
further south than you
Dan
Strippers not that expensive in the over all scheme, buy a reasonable name brand and stick with it
Nothing worse than using that cheaper product which takes twice as long or worse doesnt work at all
I use cheap product if I know I can get away with it
Reactions: Pioneer Floorcare
Andy
No Where
Doesn't Matter
Been wanting to try bonesaw.
Bonesaw from buckeye is good. It is non-butyl and contains a mixing indicator. Pour it in until the water is milky, then you have the right dilution for the water you are using.
Reactions: DAT
encapman
St Petersburg, FL
Rick Gelinas
Polyurethane can be a bear to strip. It can stripped with a GOOD stripper. But plan to work at it. Will require ample dwell time. Lots of aggressive scrubbing. And perhaps multiple attempts to get it all off the floor. :hopeless:
Or do like Michael said above. "Run and don't look back."
