Auction Auction - 6 Pack - CleanFreak® Carpet Drying Restoration Fan - 1600 CFM
Auction is for pack of 6 fans.
Bidding starts at $500
Free shipping to lower 48.
Auction ends 4/10/18 at 6PM PST
Minimum bid increment $10
Product Details
This CleanFreak 1600 CFM fan is the ultimate model for use in restoration jobs. Its lightweight and compact frame allow for you to carry more fans around in your vehicle. Weighing in at only 15 pounds, lifting and carrying this model around is extremely easy. Plus, it only pulls 3.0 amps on its highest setting! This means that you can run multiple units off of a single electrical circuit, and never have to worry about blowing a breaker. You can also easily run them off of a generator, because in some restoration work, electricity can be nonexistent.
The truly great advantage of this CleanFreak ETL listed restoration fan is its low amp draw. Run multiple units off of the same outlet to blow in different directions, and dry large areas quickly.
Position the CleanFreak restoration air mover at 4 different angles.
Features
  • Tough polypropylene shell withstands abuse and is lightweight.
  • Recessed 3-speed switch is protected from damage.
  • This fan is perfect for the restoration industry as the ETL listing is proof of product safety.
  • Unit is stackable on its side, up to 4 units high, for storage & transport.
$900+ retail value when shipping included.
I have two of these fans great for halls steps and upholstery
A lot smaller then your traditional snail but they last and work!
Hard part is who needs 6
DAT
Nevada
Bill Cheryl
I would've taken 6...it will make my swamp cooler work amazing...
