Berber problems
Discussion in 'the CleAn Room' started by realclean, Jun 29, 2018.
  1. realclean
    realclean
    Sep 4, 2012
    412
    Bossier City, LA
    Name:
    Jesse Lowe
    I clean an berber carpet yesterday and customer just called to say that the carpet now has a orange color to it.
    Now I have not seen it yet and not sure if its all the carpet or just in some areas.
    What would cause this and how should I try to fix it.
    I only preprayed with powermax and rinsed.
  2. Cleanworks
    8,692
    Name:
    Could be cellulosic browning from being left too wet or too alkaline. Treat with a liquid browning product and maybe lightly lightly rinse it. Sometimes a quick once over with a buffer and o2 encapsulated works wonders.
  3. Jimmy L
    11,049
    Name:
    Acid rinse it.
    Do you use a portable?
    SamIam and Nomad74 like this.
  4. Nomad74
    5,374
    Redding
    Name:
    Damon
    Yup, acid rinse that puppy. This is exactly why I use an acid rinse. It doesn't happen often, but when it does, it's embarrassing.
  5. scottw
    scottw
    Oct 16, 2006
    2,691
    West Jordan, UT
    Name:
    Scott Warrington
    Olefin or wool or something else?
    Provide additional information and photos when available.
    Mark Saiger and hogjowl like this.
  6. rider0992
    rider0992
    543
    Red State
    Name:
    Acid it, run a bonnet if needed.
  7. sOOper hero
    sOOper hero
    18,892
    Name:
    be willing to bet it's rare to see wool berber in Crawdadville Louisiana
    as Scott said, Jess..need more info
    is it sculptured berber or level loop?
    IS IT WOOL??
    was it heavily soiled?
    does your wand technique suck?
    (berbers give lots of cleaners problems and it's almost always due to poor wand technique)
  8. rider0992
    rider0992
    543
    Red State
    Name:
    You’re cruel!
  9. sOOper hero
    sOOper hero
    18,892
    Name:
    nah
    just brutally honest ….:winky:
    Papa John, rider0992 and hogjowl like this.
  10. Matt Wood
    Matt Wood
    4,635
    Georgia
    Name:
    matt wood
    I'll never understand that. I think berber is one of the easiest types to clean carpet. Just push the wand down a little harder to get a better connection. Boom! YOu're done
    Lee Stockwell and sOOper hero like this.
  11. sOOper hero
    sOOper hero
    18,892
    Name:
    agree
    never had a problem with berbers
    stiff sculpted berbers required more effort due to poor wand lip seal, but level loop berbers are down right easy
    the probs Jamokes have with berbers (and many low loop pile like CGD) is due most to their "sawing away" wand style .
    They "N" saw back and forth on an area of a sq yard or more with keyed wand...(like some idiot taught them)
    ......some even go all the way across a room like that.:headscratch:
    They're leaving puddles at the end of every back stroke
    IF they do give it dry strokes, by the time they get back to where they started, solution has soaked to backing ..and wicking is the result
    berbers and low loop piles are easy .
    they're just not very forgiving to poor technique like cut pile generally is
    Lee Stockwell likes this.
  12. sOOper hero
    sOOper hero
    18,892
    Name:
    PEEE-ESSS
    Jesse, my Magic 8 Ball suggests a light misting of pret'near any bonnet cleaning juice or encRapoo with damp bonnet on a rotary will fix it just fine
    rider0992 and Blue-Collar Hero like this.
  13. Derrick T.
    Derrick T.
    Apr 3, 2017
    2,270
    Reno, Nevada
    Name:
    Derrick Andrew Trulson
    Yup did one just Thursday. Berber carpet look like crap after HWE done by competitor.. I fixed it with just awesome encap boosted with h202 with my 175 and MF. Looks beautiful. And bright.
    Blue-Collar Hero likes this.
  14. Lee Stockwell
    FOJL
    14,377
    Benton KY USA
    Name:
    When I see "Berber Problems", I think hack.
  15. rider0992
    rider0992
    543
    Red State
    Name:
    Now see, yous said AlL that in 2 posts and were cruel at the same time, then tell him to use a bonnet. Took me less time to tell him.:headscratch:
    sOOper hero likes this.
  16. sOOper hero
    sOOper hero
    18,892
    Name:
    I won't go that far, Lee .
    a "hack" to me, is a loser that doesn't GAS if their work is subpar
    I like to think (and do) most "want" to be good.
    They're just unable to figure things out themselves and have to be spoon fed
    Or buy juices designed/intended to help yawks not be yawks
    yea, but you're not a bored, big mouth azzhole …..like me :angry:
    "cruel" would be punching them in the stomach and delight at watching them gasp for air .
    Not punching them to get their attention first ...soze u can help 'em after they catch their breath
    U no?
  17. steve_64
    7,269
    Only time I had trouble with Berber was with my bane and in basements. To wet to long.
  18. Papa John
    2,795
    San Francisco, CA.
    Name:
    I'm very sure the carpet is wool and Powermax is too high of a ph. for cleaning wool.
    Newbies think using the most powerful cleaner is the best-- but using the correct cleaner is wiser.
    Acid rinse and check every component used in the extraction portion of the process-- even the tech's wand technique.
    After you think you have extracted the water, confirm everything is working properly by touching the carpet with your hand to feel if the carpet is dry enough.
    scottw and Cleanworks like this.
  19. Cleanworks
    8,692
    Name:
    Also if you feel you're not getting a good seal due to the texture, slow down and do a few more dry strokes. Not going to kill you.
  20. Blue-Collar Hero
    Blue-Collar Hero
    56,663
    Elysium
    Name:
    Rich
    Remember Cole's company charged more for Berber. I think they dry cleaned it.
    Is he still in the restoration business or did he clean up on hurricane work and retire?
Share This Page
