carpet protection tape residue article
Discussion in 'the CleAn Room' started by Mikey P, Dec 1, 2016.
  1. Desk Jockey
    54,875
    a planet far far away
    Name:
    The One
    So many variables. If its tape lines we would hand spot and agitate with a volatile spotter. Maybe a POG if that doesn't cut in.
    Generally the carpet film is not that bad. It just needs more solvency than your regular precondition or you'll be fooled and end up with a re-service down the road. 2-4 oz of Prochem's Citrus Pro is what we use but any solvent additive would likley do the same.
    Cleanworks likes this.
  2. Desk Jockey
    54,875
    Name:
    The One
    I'd use a fiber pad to break it up, agitating it good. then I'd pickup what you can with a combo or blend pad. This way you're much more likely to successful when you hit it with HWE.
    Old Coastie likes this.
  3. Larry Cobb
    5,767
    Dallas, Texas USA
    Name:
    Pad agitation would be fine.
    Immediate extraction should follow the pad since it is a fast acting solvent blend.
    Total time from application to extraction should be about 10 minutes.
    All "citrus solvents" that I have seen have a residue of at least 1%.
    Desk Jockey and Old Coastie like this.
  4. Brent Norman
    Brent Norman
    Dec 4, 2014
    33
    Pine River, MN
    Name:
    Brent Norman
    I had one last month that the plastic had been down for a year! Really really bad residue! It was a white older nylon, I used Harvards dissolve all product which is a citris solvent. Took two tries with that, high heat, and 360i and brush head, but cleaned up nice!
    now on Tuesday next week I have to restretch and clean one that has been down for a couple of months while they remodeled. Problem is she has allergies to fragrance. So I don't think I can use the Harvard product. Might have to use just Acetone.
  5. Mikey P
    69,492
    Name:
    Mike Pay-oh-tay
    What about their soy solvent, does it stink?
  6. Brent Norman
    Brent Norman
    Dec 4, 2014
    33
    Pine River, MN
    Name:
    Brent Norman
    yes, it has a bit of fragrance. I don't even like the smell of it! but it works
  7. Old Coastie
    4,490
    Heart of Dixie
    Name:
    Robert my chemical pimp (Dixie Steamway) suggested Citra-Zolv II.
    I’ll let you know how it goes, next week.
  8. Old Coastie
    4,490
    Heart of Dixie
    Name:
    Before #1: It is easy to see where the plastic runner left adhesive on the carpet.
    Before #2: The steps and landing show how soil has adhered to the residue.
    After #1: Using a 50/50 mix of Citra-Solve II and distilled water, I presprayed the adhesive. I then ran the 360i brush head over it with no water or vacuum, to scrub.
    Then I applied Saiger’s Free and Clear to emulsify (“DO YOU KNOW WHAT EMULSIFICATION IS?”) the Citra-Solve II and extracted the whole shitterie. Customer showed her husband the gunk pumping out of the apo hose and he lost his appetite, hahahahaha!
    After #2: the whole place looks like new carpet. Job was done at .51/foot.
    Not shown was a furniture stain spot from whenever; it came right out. Ditto for numerous other spots that I shot with Citra-Solve II. I plan to bottle the remaining solution for future spotting.
    I also left them with a quart of Releasit DS2 made four times normal strength, as a sailor proof spotter.
    Desk Jockey likes this.
  9. Nate The Great
    Nate The Great
    8,125
    Hawaii
    Name:
    That was done on the cheap side... You are correcting a problem not just your typical cleaning... We would have been closer to $1.00sf depending on the affected areas...
    Harry Myers and Old Coastie like this.
  10. Old Coastie
    4,490
    Heart of Dixie
    Name:
    I agree, Nate. Their contractor left the plastic down for about 90 days.
    Next one I’ll be more certain of the results.
    Lee Stockwell likes this.
  11. Desk Jockey
    54,875
    Name:
    The One
    Ya done good. If I were down there I'd take you for ice cream. :winky:
  12. randy
    randy
    Feb 2, 2007
    1,084
    USA
    Name:
    Randy Royer
    I can in to this at World Bank HQ about 10 years ago. The construction company was going to have to replace 30,000 sq feet of carpet because of one hallway of about 500 sq feet. Someone had already done the solvents with truckmount rinse. It had been bonneted with a solvent shampoo and one clown tried HOST :headscratch:. Nothing had worked and ot just kept wicking back. I rinsed it with cold water & Prochem all fiber rinse to get all the chemical residue out and set up two blowers. Went to "lunch " for two hours. To solve the issue I encapped it with Cobb encap with protector. Zero issues and a huge check. They just recently replaced the carpet and it had a normal life cycle.
    Why that worked ? Ask Larry, I never figured it out . Honestly it was a shot in the dark, just trying what hadn't already been attempted. Kind of like when rust remover takes out the ink that nothing will touch.
  13. Desk Jockey
    54,875
    Name:
    The One
    Had to be all the harsh solvent Larry Jambs into all his products. :winky:
    Lee Stockwell and Old Coastie like this.
  14. Larry Cobb
    5,767
    Dallas, Texas USA
    Name:
    Probably the Encap plus actual fluorochemical protector removed or encapsulated the last of the adhesive residues.
    No solvents in that product.
Share This Page
