Cell phone stylus use
Goomer
Bronx, New York
Frank Mendo
Picked up a cherry pimped Samsung Note 4 a few weeks ago, already rooted with a custom ROM.
Huge upgrade to my old S4.
Because I consider the ability to swap out batteries a must, the N4 was as far as I could go in the Note line, and even though it is a couple of generations back, it's storage and specs are more than enough for even the heaviest user.
The feature I am most surprised to be all smitten with is the integrated stylus.
What a fooking joy it is to be able to pull out the stylus and have a new blank note page opened automatically, if that is the setting you choose, and quickly input whatever info is needed as if you were holding a pad and pen, without having to butcher the information with your big sausage fingers on a undersized keyboard while simultaneously at war with auto-correct.
Although some data like customer info would likely have to be transfered later to a different text-based format, being able to input info so fast and easy during an active phone call is a joy being a active owner/operator /one-man-band.
Opens a whole new dimension to using a smartphone.
Grand Rapids, MN
Yep, use that Sylus more than I thought I would....
cut and paste...make notes....
Put Marty's head on something else.... :)
Reactions: Connor and hogjowl
