CHECK YOUR NIPPLES!!
Royal Man
Lincoln NE
Dave Yoakum
I had a nipple coupling last week that blew to "o" ring into my wand valve.
It took a while for me to figure out why my pressure was acting so erratically.
When I took apart the wand valve I found the "o" ring in with the spring. I thought that maybe I assembled it that way by mistake. But, when I removed it the pressure was better. But, still acting erratically.
The lack of the "o" ring in the coupling was shutting off the pressure between strokes.
I replaced the nipple coupling and all is well.
Has anyone else has this happen?
Or how often do you check you nipples?
