GeneMiller
it was running at 4-5 gph even when the trigger wasn't pulled. i pulled the solution check valve and cleaned off some debri from the teflon seat. i replaced it and the o-ring just for good measure. it quit flowing but now the flow ball will only stay up for a second when you first adjust it. then it sinks to the bottom. i'm pretty sure the solution is still flowing but i'm not sure at what level. if you adjust it all the way to ten then it will work normally. i'm missing something but can't figure it out.
gene
gene
