Cimex for agitation and applying chems for HWE
Discussion in 'the CleAn Room' started by Sierra Clean Care, Jun 13, 2018 at 8:59 PM.
  1. Sierra Clean Care
    Sierra Clean Care
    Jun 20, 2016
    1,580
    Bc
    Name:
    Jeff T
    Ive got a large apt to do tomorrow. It’s 5 floors, and 3 stair cores. Instead of using the HF to apply prespray, then running the CRB, I’m thinking of just using the Cimex with the solution in the tank. Is it going to cut down on time? Do I use pads (grey), or run the brushes? The stairs I’m going to use my electric sprayer, and my little Oreck with blue brush.... can I expect the same results with the Cimex? They’ve requested HWE, no SCAMpoo...I need to cut down on the time, as the PM posted the work being done, I’ve also got 11 occupied apts to do....
  2. Cleanworks
    8,309
    Name:
    I never do suites as I am cleaning the common areas. Takes to long and you end up doing a half assed job on both. Do the building first, then post a day for doing suites. Unless it's filthy, probably no need to scrub. Use your hydro force, then get on the wand. That building will take me and a helper about 5 hours to do.
  3. hogjowl
    Feb 19, 2007
    27,050
    Prattville, Alabama
    Name:
    Marty Sutley
    Let’s over think it
    Ok?
    Matt Wood likes this.
  4. jcooper
    jcooper
    2,865
    IL
    Name:
    Jerry Cooper
    Take me a week!:biggrin:
    steve_64 likes this.
  5. Sierra Clean Care
    Sierra Clean Care
    Jun 20, 2016
    1,580
    Bc
    Name:
    Jeff T
    I’m trying a system in order to cut down on time. He building is a PITA to park at, and the suites are on every level. My porty is a POS. I’ve got a very large job coming up, and they’ve added a large extra area. I’m trying to get the system down for that job. I’ve got 7.5 hrs to get 10 hrs of work done. It pays VERY well, I’ve got to get the system DOWN. Tomorrow is a trial. If I’m able to get it done properly in 7.5 hrs, they will give me 3 more just like it. They are willing to pay 3500$.....
  6. Desk Jockey
    Rico
    56,281
    a planet far far away
    Name:
    Mr Misunderstood
    It will work great if it's trashed. The planetary action is excellent for scrubbing. I'd use pads over brushes.
    If it's only moderately soiled, it may not be worth the effort. It could actually take you longer manipulating the beast when it's not needed.
    rider0992, encapman and Matt Wood like this.
  7. Cherokee
    Cherokee
    Mar 8, 2015
    64
    Cherokee Village, Arkansas
    Name:
    Matt Middleton
    Ditto.
  8. Sierra Clean Care
    Sierra Clean Care
    Jun 20, 2016
    1,580
    Bc
    Name:
    Jeff T
    The last time they had it cleaned was 2014. The building is full of foot draggers and walkers.... it’s a seniors building. The halls look like the animal trails in the Serengeti. There’s no way spray and splash is going to cut it. I need to agitate. Some of the residents have already asked about ‘lingering chemical smell’. SO, I will ask AGAIN, CIMEX, OR, CRB......
    Matt Wood and Desk Jockey like this.
  9. Desk Jockey
    Rico
    56,281
    Name:
    Mr Misunderstood
    Go with your plan. Cimex will do all your agitation and then just a simple rinse is needed.
  10. Sierra Clean Care
    Sierra Clean Care
    Jun 20, 2016
    1,580
    Bc
    Name:
    Jeff T
    Thank you Richard..... I don’t care what these other MOOKS say about ya, YOU ARE MIGHTY....
    Desk Jockey likes this.
  11. hogjowl
    Feb 19, 2007
    27,050
    Prattville, Alabama
    Name:
    Marty Sutley
    Everybody knew you were going to do it anyway
  12. Desk Jockey
    Rico
    56,281
    Name:
    Mr Misunderstood
    lol
  13. Mikey P
    71,854
    Name:
    Mike Pay-oh-tay
    You're about to discover that even the strongest of pre sprays dont make dirt disappear like a well formulated encap.
  14. Cleanworks
    8,309
    Name:
    Get the truckmount set up then one guy on the cimex and follow on the wand.
  15. Justin Stockwell
    Justin Stockwell
    Mar 18, 2007
    1,227
    On trashed cgd nothing works as good as a Cimex for agitation. Most of the time it is a hassle to haul it out. But in big areas it is amazing. Shower feed some diluted prespray after the initial prespray with HF.
    Steve Lawrence likes this.
  16. Matt Wood
    Matt Wood
    4,469
    Georgia
    Name:
    matt wood
    The cimex will definitely eliminate the strong smell, because you're not putting any mist in the air like a HF would do. You can get away with adding some more butyl in the mix and not have to worry about the smell being too much of a factor that way.
    The only thing I was concerned with is getting that cimex up 3 stair ways, unless there's an elevator waiting for you.
  17. Steve Lawrence
    Steve Lawrence
    Oct 10, 2006
    2,791
    Ann Arbor
    Name:
    Steve Lawrence
    Be careful. These old codgers can be fussy. Sounds like a good job!
  18. encapman
    encapman
    1,561
    St Petersburg, FL
    Name:
    Rick Gelinas
    Put your prespray into the Cimex tank. Prescrub and apply the prespray in a single shot. Use the beige FiberPlus pads for residential carpet (not gray). Feather out the prespray solution lightly. You'll have terrific agitation. Then extract like normal. Prepare to be impressed. :clap:
    As Matt said, pulling a Cimex up a bunch of stairs can be a pain. Hopefully you have BigBoy wheels on your Mex. And if you have a helper - it makes it easier if you have one person pulling on the handle while a second person helps to lift and guide the head up the stairs.
  19. rider0992
    rider0992
    479
    Red State
    Name:
    Just so you know, my chimps, uh crew are using your method in one of my schools. It works great. They’re zippering after Cimex because it wasn’t flushed last year. But man, I wish you could just Cimex around those seniors.
    Best of luck on that! Be careful!
    By the way, I know I’m an idiot, but they’re on the 2nd floor with an elevator using a Bane with a zipper with propane heat, and the zipper is killing it. Fyi
  20. Old Coastie
    4,916
    Heart of Dixie
    Name:
    Load your Cimax with encap solution. You can speed up the extraction with a clear conscience.
Share This Page
