Louis
Has anyone tried this? I'm thiking about putting a quick connect off of my pump so I can run a spinner at 1200 psi. I can only go to 600 psi with the little giant. Just enough to spin the spinner.
Mardie said:I was going to mention this but did not want to be molested by MB member's. so here we go. No problem at all using cold water especially for grease.All well trained facility cleaners have been trained to use the coldest water possible. Grease and oils are attracted to cold so as long as the water used is colder than the surface being cleaned it will work great. When using hot or warm water the grease and oils will naturally migrate to the cold which is the surface of the floor.The chemistry dose the work. Have done several greasy T/G job's using the coldest water possible and they cleaned up with ease and the result'e were fantastic. The one reason spinners can get away with using hot water is because they can pick up the dirt grease and oils before it get's a chance to re-cling to the cold surface which is what it is attracted to.
Out Of Character said:Our machines will do 1200hot and 3000cold. On some commercial jobs 1200 doesn't do it, especially when there is wax in the grout. Often we are able to go twice as fast or better at 2500psi.
Put the quick connect on the regulator not the pump. If you run a pump with no regulator you cannot release a trigger or stop the water, you'll blow the head.
GeneMiller said:I always bypass my little giant when i had one. Cold waer cleans fine. Good chemistry gets it done
Gene
3000?
Do you not have grout being blown out?
