Keeping the machine clean is all that's recommended for daily maintenance. The brushes should be removed at the end of each work day for a good cleaning. Using a shop vac works well to suck the lint and fuzz from the brushes. Then wipe down the metal surface underneath the machine. Using some WD-40 on a rag to wipe down the surfaces helps too, to offset/displace moisture. Wiping the machine down with WD-40 also helps to keep the stainless steel looking good. But be careful to avoid squirting WD-40 into the bearings because it will wash the lube out of the bearings.
Also, keep an eye on the brush wear indicator. Replace brushes when they wear down. That's another benefit from removing the brushes each day, is that you'll most likely install them in a reverse order. By swapping/reversing the brushes it helps to extend the useful life of the brushes.
Regarding the
CRB Industries machines - those are NOT the Austrian machines.
