boazcan
For those of you that have tried to or do on occasion, have you ever measured the actual pressure that you experience on each tool when you dual on tile?
We have recently tried this more often after only using on very large jobs where we would normally machine scrub it. On residential, we rarely scrub by hand or machine. This is affecting the quality because our pressure is dropping so much when both tools are in use.
Before I buy two separate pressure gauges to do my own testing, I am curious what any one else has found in dual wanding tile.
I have a 5cp3120 - 4.5 gpm. Can I do something different (other than replace the pump) to reduce to drop in pressure? We are usually around 1200 psi at the truck, giving us around 1000 at the wand based on 200 ft of live solution reel. I bumped to 1400 when dualling, but guess that we drop to 700ish when both are running.
