Encap and SaigerCide a deadly combo
encapman
St Petersburg, FL
Rick Gelinas
If you're concerned about affecting the encapsulated polymer, here are a couple of ideas.
1) We've tested Odorcide and found that their products won't blow out the encap polymer. We've recommended it for years for using with Releasit. Saigercide at a low dilution might work ok too (but I haven't tested it yet). Mark maybe you could send me some to test; I'd love to be able to recommend it if it's compatible.
2) Or you could add a few drops of essential oil per tankful. For example you could try Peppermint oil. It's reasonably priced. Smells fresh. And just a few drops per tankful is all it takes. Or you could try orange, lemon, grapefruit, pine essential oil - whatever you like, they all smell great. Essential oils can be cost effective and they smell fresh (not synthetic/fake). And since you only need to use a few drops per tank, it won't impact the polymer.
Here's a link for Peppermint oil on Amazon:
https://www.amazon.com/dp/B01258AK8Q?th=1
You guys trust a manufacturers chemist when you know better than him? :shifty:
He has never been a cleaner, he only knows his line. He doesn't know those double secret potions you concoct with a dash of two or three brands mixed together. :eekk:
That foo wasted his time getting an Edumacation on mixing. Shoooot you know how to mix! Plus it has to work great, you never get call backs. :winky:
Reactions: encapman
encapman
St Petersburg, FL
Rick Gelinas
Well this manufacturer's also been a cleaner since the early 80's. :icon_cool:
In fact I still have a commercial carpet cleaning business... www.KleenStep.com :winky:
Grand Rapids, MN
Will be happy to send some out :)
Thanks by the way
J Brown
Georgia
Jeff Brown
3 drops in 5 gallons will be how noticeable for how long to the inhabitants?
You'll need a little more than 3 drops , but it doesn't take much. Some oils are more aromatic than others, I've been using them for years because there safe, don't leave a residue or hurt the polymers in encaps .
The oils I like the most are lemongrass, spearmint, peppermint, wintergreen plus I blend certain oils for there unique ability to sanitize and control odors.
But......but.....but......you just private label your scampoo.
Heart of Dixie
But do they make every job a festival?
Every time I add Saiger’s Cide, the conga line goes around the block. In the nursing homes every door opens as the residents pop out for a good sniff, followed by plaintive cries of “would you do MY room?”
Redding
Chemistry doesn't lie.........it doesn't mix
I disagree. My results are fabulous. I'll make a video of the one I did last month of how it's holding up.
Also, nowhere on the bottle of SaigerCide is the word "Enzymes" printed. In fact, it advises to mix with your prespray as a booster.
Bob Pruitt
earth
Robert Pruitt
I know I don't understand encapsulation very well but I wouldn't be able to use the Orbot Vibe in that way...on residential apartments. I understand using encapsulation on commercial. I have a heavy pain in the back portable I use if I can't reach with the truck mount.
But like I said... maybe I don't understand the process.
Redding
Same here Bob. I only use it on CGD, unless it was in my personal hall way.
Reactions: Bob Pruitt
Redding
Sorry the video is sideways. Just tilt your head. No signs of residue and the client is still happy with thebfresh scent from the cleaning.
