Fastest most effective approach to upholstery cleaning?
icleancarpetz
Rafael Samson
there a few factors to consider such as material, delicateness of fabric, soil load, size, material, etc etc.
Sofa size being 7ft, 5ft and chair.
All things considered, My approach is cushions, arms front skirts back cushions, backing.
I don't particularly like cleaning upholstery, but it pays for the doughnuts.
Is there a better approach?
Russ T.
Slater, IA
Russ Terhaar
I need to go to school I think. Pemberton's has my name on it.
Upholstery seems like so much work compared to carpet. A small 4 " tool takes a while to cover that amount of surface area.
I alway start on the inside back. If working from the front I clean the deck first, just so any driping don't leave a water ring.
After the back the inside arms, then outside and the outside back. Then front and last is the cushions. I might depending on colorfastness, prespray and agitate during the base cleaning allowing extra dwell time.
Low moisture techniques, with upholstery shampoo or encap formulas can be faster, and in some cases safer as well.
Just recognize that soft pile fabrics, such as natural fiber velvet and chenille, will dry with a harsh hand, which your customer won't like.
Also, in most every case, your fabric protector won't work as you promised.
If the fabric is made of an oil loving synthetic fiber, it's difficult to break oil bonds with low moisture methods.
Know the fiber, the fabric, the soil, and the customer first.
San Francisco, CA.
Man You spoiled Kids have it so easy today when it comes to Upholstery cleaning.
The SS upholstery tool or similar has already made the task easier and faster.
Rushing upholstery cleaning any further could mean sub par work or problems once it dries.
If you don't like the task- then charge more until you do like it- and do a thorough job.-- otherwise your doomed to buy some furniture.
Sea sponge and or horsehair brush can work quickly on lightly soiled or delicate fabrics. Terry towel dry or buff off with orbital pads. The piece would need to be qualified to be able to be cleaned this way.
John is right, the old days had some nice tools, the Kleenrite, the Prochem. But the evolution from the dry tools from the Drymaster to the Sapphire have made upholstery cleaning so much easier and safer.
Reactions: Jim Pemberton
jwfoulk12
PA
Justin Foulk
Come join me in June!
Reactions: Russ T.
dekeil
HILLROSE, CO
DOUG
Vapor steam does not extract?
May be my towel is lying to me.
Maybe pads on carpet do not extract?
Maybe my washing machine is lying to me
Maybe it just works for me?
Closed minds are great for staying put in your box.
You all have great day!
dekeil
HILLROSE, CO
DOUG
I use hot water also.
Been cleaning about two decades and still learning.
I was pointing out their is more than one way to skin cat.
If you are not open to alternative clean what is this board For?
If offer a different method why say it does work.
Have you had experience with alternative methods and have not worked for you. Just maybe they have worked for others.
Just respect others who maybe using a different methods.
Do not just say (they do not extract, good luck with that.)
Thanks
I am to old to stay in the box.
Have a great one.
Reactions: Condog and Mikey P
Thanks
Have a great one.
I'm open to all methods, most here know that.
Heart of Dixie
Doug, vapor works for some things quite well. For others, it is a guaranteed disaster; microfiber for instance.
What are some of your experiences with vapor?
Reactions: Condog
dekeil
HILLROSE, CO
DOUG
I have used on micro upholstery and not had a bad experience.
I have used it on drapery with great results
You use a towel and low setting on your vapor steamer and go up from their. Trick is not to get towel to wet change your towel often.
You do not want to soak the upholstry.
Mist your pre-spray very lite .
Sometimes I just mist the towel it really lift the body grease from upholstery
Have good one
Reactions: Old Coastie
Doug isn't it slower? I would think it would be a much slower process. We've used steam and towel to accelerate spot removal but never for overall cleaning. The nice part is you would get a good kill on most bacteria or viruses.
Benton KY USA
Fastest
Most Effective:
2 drywall saw- horses on paved driveway. Put couch on it. Prespray with HF. At 400 psi rinse with pressure wash wand and 40 deg. tip until black and brown runoff water turns clear.
Towel off and return to dorm or rat hole when dry.
San Francisco, CA.
Interesting --OK you have a audience now-- so tell us:
I have a garment steamer will that work as well?
Is the towel in the other hand or on the tool?
Do u have to dilute the pre spray more then usual- do u apply it to the towel or fabric-- or no pre spray?
When should This method Not be used?
I would think your method is much better on drapes then OMS-- but what about shrinkage?
Hawaii
I remember Tony Wheelwright telling me he used a steamer to activate the pre-spray when cleaning upholstery... His pictures were pretty impressive...
Fastest
Most Effective:
I actually did that once to a mud flood victim.
It was kind of fun.
