Helix cleaning llc
Hey guys I was wondering what your favorite combination of prespray / rinse was for residential.
I'm trying to keep it simple and use one chemical.
Just what I wanted to hear!I highly recommend having three pre spray choices
And the ability to use three rinses
- Silver Bullet High pH Nuke Juice
- Every day, fresh water rinseable 9 ish pH powder
- Neutral pH wool and baby safe
- Soft water
- Alkaline
- Acid.
Just the way it is.
Thank you so much, I'll do some research on specific products for each type.
I understand when to use the three different presprays,
could you explain when to use the three different rinses?
Thanks!
When you use the alkaline for restaurants and hellholes, do you still use a prespray beforehand?
I agree 100 percent. You can use the Procyon plus powder as your prespray and your Rinse. Combined with a brush pro or rotovac brush head, you are good to go.Here's a great question
IF you could only have one cleaning agent on the truck, what would it be?
I would have to go with Procyon.
You can always crank up the heat and agitation
Or reject shitholes.
Cobbs Stainresist Powder neutral pH with a fresh water rinse.
