Flex Fire
Discussion in 'the CleAn Room' started by Swani, May 16, 2018.
  1. Swani
    Swani
    Oct 25, 2016
    613
    Montana
    Name:
    Nick
    I'm wondering if on the filthy carpets I could use an alkaline prespray like Code Red or Biobreak and rinse with Flex Fire alkaline rinse, then post bonnet with Encapuguard Green to neutralize. I almost always post bonnet anyways.
  2. Jimmy L
    10,778
    Name:
    To neutralize or NOT to neutralize is the question..............Mmmmmmmm.
    Better ask all the people who SELL chemicals to carpet cleaners. : )
    Steve Lawrence likes this.
  3. steve_64
    6,996
    At what point do you rinse all that out?
  4. Swani
    Swani
    Oct 25, 2016
    613
    Montana
    Name:
    Nick
    Do you not use a rinse agent?
  5. steve_64
    6,996
    Yes but that combo sounds like you're leaving a lot behind.
    I use a soft water rinse often and have been using odercide way diluted more and more.
    Swani likes this.
  6. steve_64
    6,996
    Prespray scrub and rinse on the nasties. The odorcide works really good on the nasties but if it's a rental I'll use an emulsifier.
    I'm using up some of Cobb's stuff now but not sure what I'll get next. Not sure it really needs an emulsifier to be honest. I had been using just an emulsifier on rentals that don't get prespray but getting away from that too since I got the white magic a couple years ago. 15265003656431333262668.jpg 15265003656431333262668.jpg
    Swani likes this.
  7. scottw
    scottw
    Oct 16, 2006
    2,642
    West Jordan, UT
    Name:
    Scott Warrington
    Rinsing with Flex Fire would remove most residue and alkalinity from your prespray. Always several variables like your flow rate and how fast you move the and, etc. This will bring the pH down closer to neutral.
    The Encapuguard Green is on the acid side and would leave the final pH reading on the fiber slightly acidic.
    Swani and Cleanworks like this.
  8. Swani
    Swani
    Oct 25, 2016
    613
    Montana
    Name:
    Nick
    Is there any issues with leaving the carpet acidic vs neutral?
  9. Derrick T.
    Derrick T.
    Apr 3, 2017
    1,942
    Reno, Nevada
    Name:
    Derrick Andrew Trulson
    Maybe cause more oil to attract fiber and cling such as bare foot traffic. I remember an carpet cleaning article that carpet stay cleaner longer closest to PH 8 with minimal residue as possible. I am not sure about this.
    Swani likes this.
  10. Acp
    Acp
    May 15, 2017
    328
    Seattle
    Name:
    Bjorn Marshall
    pre spraying stronger chems at low temp is one thing,
    cleaning a stairwell with not as much ventilation and huffing the steam of Flex Fire is a whole different deal.
    Im not really a fan of rinsing with anything that has much cleaning power, I dont need to be breathing what ever is in formula 90, etc
    Swani likes this.
  11. scottw
    scottw
    Oct 16, 2006
    2,642
    West Jordan, UT
    Name:
    Scott Warrington
    Not really. Some dyes, especially used for nylon and wool are more stable and durable in an mildly acid environment. For other fibers, it does not matter much.
    Swani likes this.
  12. Nomad74
    4,681
    Redding
    Name:
    Damon
    Flex fire is good stuff. Damon Approved. Even though it smells like disgusting watermelon.
    scottw and Swani like this.
  13. Derrick T.
    Derrick T.
    Apr 3, 2017
    1,942
    Reno, Nevada
    Name:
    Ive been using deep fiber rinse...works great
    Swani likes this.
Share This Page
