Im seeing recommedations of getting a 10k watt (8k running) generator for guys that want to run a porty and booster from the van .. seems like overkill.
Im guessing under a 100 amp total draw for some of these guys ..
That is a good size for a generator to run an ETM from the van. That's what I have for my ETM (
A 10K surge, 8.5k running), and it will run it all day long ( 12 years old). It will power these units at the same time - 4 HO vac motors (dual wands), a 600 PSI or 1200 PSI pressure pump, and 2 APO's (dual wands). 240,000 BTU LP heater for heat!
I use a fuel tap for mine so it draws from the van gas tank.
A large cooling fan is directed across the generator to help dissipate heat.
Overkill is justified in this case. It's hot inside a van on a hot day, so a beefy unit will work for a long time. Mine is a Northstar/Honda.
