GPM versus PSI in Cleaning Applications
Dallas, Texas USA
If You up the jet size heat exchange machines won't maintain temp. My experience is best TnG cleaning results are achieved by using rocking chems, mechanical agitation and high temperature rinse.
If those three criteria have been properly satisfied then psi and flow are subordinate.
I suggest hi temp will out perform flow and psi consistently.
With Heat Exchangers & Heaters . . .
the quantity of heat BTU's transferred to the water is increased by
flowing more water thru the heating device.
Temp may drop, but the total amount of heat transfered to the carpet is increased.
Steve!
Remember when you got the new tm and were like... Should have done that a long time ago.
The glide is kinda the same thing. It will make things easier for you.
Not all glides are created equal. I have a couple of glided aw29's, a 2 inch westpak and my new Mach 12 with Pmf's 2 piece glide. The Mach 12 gets a better seal and is harder to move than the others. Much better extraction, you can feel the difference. I used Tom's glided swivel wand on a commercial job (not mine) and it was a real pleasure to use, probably the best extraction of them all. Although I haven't used it, I bet the Mach 15 with a glide would be a joy to use if you need a 2 inch tube.
That tears my rotator cuff. I probably could cut a foot off that wand.
Mine is shot now lol. But it works.
I want to try a machine 15 glided. I've priced them just to many other things going on to pull the trigger without trying it first.
I love my Mach 12. I don't use 2 inch wands except for shag of very deep pile carpets. The small difference in drying time isn't a concern to me or my clients. If I need to speed dry anything, I bring some fans. Make sure it's the titanium version. It's much lighter than your average stainless wand. My Mach 12 is almost half the weight of an aw29 which is not a heavy wand to begin with. If the Mach 15 works as good as the Mach 12, you'll curse yourself for not getting it sooner.
kmdineen
Redding, CT
Kevin Dineen
If flow trumps pressure for rinsing, why does the Zipper SS @ 4 to 6 flow rinse better than the standard Zipper @ 12 flow?
Dallas, Texas USA
Which person is saying the Zipper SS @4 to 6 flow rinses better
than the #12 flow of the std. Zippper ?
Is Eric agreeing with that . . .
Impact will increase with the narrow angle jets of the SS.
kmdineen
Redding, CT
Kevin Dineen
It is my understanding the benefit of having the Zipper SS is to better rinse greasy restaurants and rat nasty jobs. I think both Chavez and Saiger posted that was their experience with the Zipper SS.
We were talking jet size and flow several years ago. It wasn't the pressure but the water droplet size. The bigger droplet has more impact and more flushing ability. That's why I switched to 03 jets on my Greenhorn. Using the 02s just didn't seem to rinse well enough. Everyone seemed to want to go to the 02 jets, most likely for the heat to keep up in hx systems.
Having the higher flow in the wand also got the heat to the carpet faster.
MLPW
Georgia
BLA,BLA,BLA
Unless you're using a cheapo wand where some overseas distributor just slaps some jets on without any concern, leave the wand alone. If it's from a reputable company, they'll know what flow works best with the design of the specific tool. Just adjust your psi to the wand you've purchased, and you'll be fine.
ID10t
Canada
Joe
Will running a acid or an emusafier impact the flushing capabilities of low flow or high flow?
Benton KY USA
BLA,BLA,BLA
Bad advice in many cases.
Benton KY USA
BLA,BLA,BLA
The jets have a simple numbering format, usually sized at minimum flow depending on several other variables including the preference of the vendor.
Don't assume "factory settings" are right for you...or anyone.
Test for yourself.
Dallas, Texas USA
Many U.S. wand manufacturers size the jets incorrectly on their wands.
One 2-jet 12" wand from a "west coast" manufacturer had two #01 jets,
instead of the two 03 jets we would use.
Carpet would not of cleaned well with 1/3rd the amount of water.
Very little IMPACT to break the soil loose.
Reactions: vibra-vacster
MLPW
Georgia
Thanks for agreeing with my statement. You don't seem like a cheap overseas distributor, so I would trust the flow you put on your wands.
MLPW
Georgia
I don't mean to grind this debate in the dirt, but I think I know which west coast manufacturer you're talking about, and the wand they're sizing as a 2flow is under the portable wand section, which is really what it should be. The wands in the truckmount wand section are at a 6flow like it should be also. So I think they're correct on why they set it up that way.
The only reason you see 2 or 3 flow wands, is so that the heater on the portable can keep up. On older 100 psi portables that we used to use, we usually had a 6 flow. Also, the so called 500 psi pumps you find on some of today's portables won't give even 150 psi on anything larger than a 2 flow. You need at least a 1/2 HP motor to get 500 psi at 1.5 gpm which is about a 4 flow.
Mighty Phil
Penrith
Philip Mathot
Sorry to be late to the party. But I think I disagree with what you are saying Larry.
My thoughts are that you need enough psi pressure to dislodge soiling through the kinetic energy of the droplet (assuming pre agitation has been neglected), and then redirect the rest of your pumping capacity to flow. You do this through jet selection and setting the static pressure at the unloader/regulator of the machine. Here is how cleaning power is calculated (below). Note that pressure and flow are identically matched.
Do you want to calculate the cleaning effect of a pressure washer? Simply multiply the pressure in BAR x the flow in LPM and divide by 600. So a domestic pressure cleaner at 1200 PSI or 83 BAR (divide PSI by 14.5 to get BAR) x 6 LPM /600 = 0.83 which is not great. But increasing the flow to 12 LPM, doubles the cleaning power at the same pressure!
Phil.
