Haze on Tile
Discussion in 'Hard Surface Hub' started by realclean, Jul 31, 2017.
  1. realclean
    realclean
    Sep 4, 2012
    406
    Bossier City, LA
    Name:
    Jesse Lowe
    What is the most common cause for haze on new construction porcelain tile?
    How hare will it be to fix?
    I have not seen it yet, but will go take a look this afternoon and may have some photos
    I was told it's brand new construction porcelain tile that looks like a wood floor.
  2. Mikey P
    71,817
    Name:
    Mike Pay-oh-tay
    Common cause?
    lame clean up crews.
    Hard to fix?
    Not on Porcelain if you have a 175.
    Fat Mike and Jim Pemberton like this.
  3. realclean
    realclean
    Sep 4, 2012
    406
    Bossier City, LA
    Name:
    Jesse Lowe
    I do have a 175.
    What is the procedure?
  4. scottw
    scottw
    Oct 16, 2006
    2,665
    West Jordan, UT
    Name:
    Scott Warrington
    Likely some of the grout smeared onto the tile.
    Clean with an acid side cleaner such as Viper Renew. A little dwell time. If it is very heavy, scrub with brush on 175 or similar type of agitation. Rinse while wet. Don't let it dry on the surface or you will be doing it over again.
    Old Coastie and Jim Pemberton like this.
  5. Jim Pemberton
    7,830
    Name:
    A common problem on new construction clean up jobs.
    Make sure you get paid for the time and trouble to fix this
  6. Old Coastie
    4,908
    Heart of Dixie
    Name:
    Jesse, look closely at the grout lines to see if they are anything but even and smooth. If the grout was poorly applied, the cleanup will be subpar and you may de dealing with vinyl additive smearing, possibly epoxy smearing, or just plain cement haze. Alcohol, acetone, Viper Venom, in that order. If you can't tell the difference in grouts, take all three and do a wipe test.
    Then again, it could be as stupidly simple as mop residue from the sheetrock dust! Good luck!
    scottw likes this.
  7. clean image
    clean image
    Oct 5, 2012
    668
    Orlando
    Name:
    Carl Maddock
    Many of these tiles, wood plank, have defects in them,
    Make sure to test for desired results
    Old Coastie likes this.
  8. realclean
    realclean
    Sep 4, 2012
    406
    Bossier City, LA
    Name:
    Jesse Lowe
    Now that I looked at it I could not see any haze really. The customer was complaining that you could see foot prints on the tile.
    If there is haze on this tile it is very hard to see.
  9. Chris Brown
    Chris Brown
    Apr 2, 2016
    48
    Sacramento CA
    Name:
    Chris Brown
    It should be very easy to see.
  10. Old Coastie
    4,908
    Heart of Dixie
    Name:
    Sounds as if soap residue was left o n the tile. You'd only see the footprints from the right angle in the right light.
  11. steve_64
    7,188
    Depends on the time of day. If new home owner is seeing it they probably see it in the evening when the sun is going down. It may not be visible in the morning or early afternoon.
  12. steve_64
    7,188
    Probably drywall dust that wasn't removed completely.
Share This Page
