How confident are you in your carpet protector?
Discussion in 'the CleAn Room' started by Mikey P, Aug 24, 2017.
By Mikey P on Aug 24, 2017 at 11:29 AM
  1. Mikey P
    69,583
    Name:
    Mike Pay-oh-tay
    What brand do you use?
    How and when do you apply it?
    How long have you been using this product?
    Any complaints?
    Do clients insist you reapply with every cleaning because they see the benefit?
    What promises are made to the client?
    Any guarantee?
    Have you tested it in your own home?
    Would you sell it to your mother or pastor?
Comments
    1. Tom Forsythe
      Tom Forsythe
      Dec 19, 2006
      193
      One other variable comes into play. For 18 states and DC including California we only sell the Maxim Advanced for Upholstery as our solvent based formula, Maxim Fine Fabric, is not legal to sell. In terms of performance, long term water and oil repellency tests are almost equal with a slight edge to the solvent based protector. We added the Dye Loc to minimize any color stability differences between the choices. The main difference is that some fabrics do not like water resulting in shrinkage and texture change. A lot of cleaners as a default mechanism, which I understand, protect with a solvent based protector. Solvent based protector of any formula are not legal in California. In the other 17 states and DC, you can sell a solvent based protector if you have 40% low VOC solvent in the formula. We discontinued this formula years ago as cleaners often applied too much resulting in a fabric that could take over a week to dry. For those of you who are committed to the upholstery business, I would start working with a water-based protector as future sales of an appropriate solvent based protector are uncertain, once current supply of C8 version runs dry.
      Page 36 Consumers Product Regulations for California “Fabric Protectant” means a product designed or labeled to be applied to fabric substrates to protect the surface from soiling from dirt or other impurities or to reduce absorption of liquid into the fabric’s fibers. Page 64 Consumer Product Regulations for California states that for non-aerosol is allowed only 1% VOC from Dec. 31, 2010. The base of any fluorochemical is a VOC before any carrying agent is added. There are low VOC solvents approved but they would only be able to have 1% fluorochemical where most have at least 10 times that amount.
      ruff likes this.
    2. Bob Pruitt
      Bob Pruitt
      May 22, 2016
      1,969
      earth
      Name:
      Robert Pruitt
      Thank you Jim. Yes I was being ironic or something but it's still over complicated for me in Florida. Sorry if you take that personally Tom. I'm not new at this and I work with Interior Designers here all the time. A few are like you have described. Mostly they are trying to satisfy people who can have whatever they want. I'm sure I could learn plenty from Mr Pemberton. So could you.
    3. Tom Forsythe
      Tom Forsythe
      Dec 19, 2006
      193
      I have been fortunate to have known Jim Pemberton for years and have learned alot from him. We consult regularly on technical topics that would bore most, but we both are trying to simplify as much as we can in a complex world. Manufacturers are caring less about practicality and cleanability than in the past. I do not know about Jim, but I always enjoy any technical discussion between us. Sometimes you have to leave it complicated when a simple solution can lead cleaners into trouble. In short, the fabric determines the protector that is to be used.
    4. Russ T.
      Russ T.
      Sep 26, 2008
      3,430
      Huxley, IA
      Name:
      Russ Terhaar
      I've been using Maxim Advanced on carpet and upholstery. I have definitely seen it work first hand. The most dramatic was a commercial setting coming off a parking lot. The carpet would turn black in under a months time. It was quite dramatic and horrible looking in this medical clinic setting. The carpet was a very light tan color. Applying Maxim made a world of difference. I came back a month later and it still looked great. The cleaning took a fraction of the time as well.
      It seems like we go through waves, stretches where I sell it a lot...and then days will go by and it's just not selling. Mel does mention it to every customer over the phone and I try to give them good value while in the home.
      Practically speaking, who in the world would have the room in a carpet cleaning van to store 6-8 different protectors?
      I think the excessive choices sometimes turns us cleaners off.
      All while Saiger Sauce flies off the shelf because it does so many things well.
      scottw and Bob Pruitt like this.
    5. Tom Forsythe
      Tom Forsythe
      Dec 19, 2006
      193
      Complexity is in the eye of the beholder. For those of us who are not equipment gurus, a truckmount is amazingly complex, but most have learned to use it everyday. We have 8 protectors for all of the industry's special needs. I would choose two for your truck, which would be Maxim Advanced and Advanced Protector with Teflon (80% of our sales). You may want different ones for your rug plant sales. If you treat new fabric for designers or clean high end upholstery then you will want the best protectors available for upholstery (one choice if you live in the low VOC states). Australia only gets to pick one (Maxim SOS great for wool)as it is the only one we sell that is legal in that country. The complexity is not in the products but it is in some of the fibers or carpets you are asked to protect.
      scottw and Russ T. like this.
    6. Scott S.
      Scott S.
      Feb 3, 2008
      3,131
      PA
      Name:
      Scott
      When i apply on upholstery i always wear gloves so as i aplly i like to rub in into the fabric as i go. So its not just sitting on the surface of the fabric.
      scottw likes this.
    7. Bob Pruitt
      Bob Pruitt
      May 22, 2016
      1,969
      earth
      Name:
      Robert Pruitt
      I wonder how many products Micro Seal and FPA have ... 2 each is my understanding. Water based and solvent based. 8 seems overly complex.
    8. Jim Pemberton
      7,581
      Name:
      Just because eight are available doesn't mean you need to use eight Bob. I understand your frustration, believe me. I used to work for and then ran a cleaning company back in the age of dinosaurs.
      When a Tom Forsythe knows things that can create better products that are targeted for specific fibers, it must be difficult not to create and promote them for what they all do best.
      What each cleaner does with those choices is up to them. As I said, when I clean now (friends, family, and rental properties), I use two. If I had a business that didn't clean much in the way of fine fabrics, I could get by on one (Teflon or Scotchgard).
      If I were cleaning for a living today, I might burn test carpet yarns and apply products specifically targeted for "the dreaded polys" versus nylon versus wool, but then again, maybe I wouldn't go to that much trouble.
      As much as I try, its difficult to really be objective when I don't live a carpet cleaner's daily life day in and day out.
      Mikey P, ruff, Tom Forsythe and 3 others like this.
    9. ruff
      8,991
      San Francisco, CA
      Name:
      I have no problem with choices. And if a product will provide my clients with better protection I'm all for it and will buy it.
      The issues for me are:
      1. Clarity. Which product will do better and for what fabric, type of stains & circumstances.
      2. Is the difference substantial enough to justify carrying an extra product?
      3. A little of trust. In other words- I'd like to know that it is not just fluff, designed so that we buy one more product, but a real advantage. I do trust Tom and Scott.
      And if we can get Tom to separate his paragraphs my job will be complete :winky:. Tom- Period then click Enter.
      Mrice and Bob Pruitt like this.
    10. Jim Pemberton
      7,581
      Name:
      :biggrin:
    11. Tom Forsythe
      Tom Forsythe
      Dec 19, 2006
      193
      Thanks, I have been wondering about paragraphs. I have separated the text by a few lines without working. In many other places, you hit enter and it is posted.
      It works, the only problem is now I have to remember where this works.
      Ofer, I asked my main supplier about Leaping Bunny. He had not heard about it. He learned that it is related to cosmetic products where significant testing of animals has been utilized to confirm products are safe on human skin.
      ruff and Jim Pemberton like this.
    12. Loren Egland
      Loren Egland
      Oct 18, 2006
      1,087
      Antioch, California
      Name:
      Loren Egland
      I enjoyed reading this thread. However, I find it odd that 3m scotchgard has not been considered along with the other brands. It is cheaper to buy than teflon. :)
      I used to give a separate price for a fluorochemical product and a similar product with dye blockers. It seemed like the product with dye blockers was not as likely to have a spill beed up, and customers seem to like that even if there was less stain protection. I also find it less unerving to promise resistance to soiling than to dye stains.
      Btw, does Guardsman still make Carpet Guard? I used to use a lot of this product years ago. It seemed to be a much better product than some of the cheap silicone protectors available, and they claimed both soil and oil resistance with their product. They were even willing to pick up the carpet stain warranty if it voided the manufacturer warranty.
      Mikey P likes this.
    13. Larry Cobb
      5,774
      Dallas, Texas USA
      Name:
      Bob Pruitt likes this.
    14. Bob Pruitt
      Bob Pruitt
      May 22, 2016
      1,969
      earth
      Name:
      Robert Pruitt
      Think I might finally give Larry's product a try. A case and blotter cards and pamphlet. Have been very skeptical that the same product can seal grout and protect fine fabrics...but the product I thought was the best actually attracted dirt in the test image.
    15. Cleanworks
      7,207
      Name:
      I use only DuPont Teflon and Teflon for wool. I really don't want to be spraying solvents, especially in my clients home. I now wear a respirator when spraying Teflon. You dont want that building up in your lungs.
    16. Larry Cobb
      5,774
      Dallas, Texas USA
      Name:
      Bob;
      We actually ship drums of Ultraseal to a leather hat company for protection on their hats.
      They tested several products before choosing our solvent Ultraseal.
    17. randy
      randy
      Feb 2, 2007
      1,086
      USA
      Name:
      Randy Royer
      I used completeseal (now microseal) for years and years. Now they want you to buy a dealership and $10,000 worth of protector. NOT HAPPENING, so we occasionally use Cobb's Ultraseal ( it's a decent protector) and steampro solutions. That being said we aren't selling anywhere near that amount of protector we did back in the 90's. Some of that is because we are aren't cleaning anywhere near that amount of upholstery that we did in years past, but I attribute much of it to channel 4 doing a consumer affairs segment on how protector is a rip off. That 10 minutes of local news cost me a lot of money. Much has changed in my 27 years in this business.
      On commercial carpet we will use an encap product with protector if we can sell the idea. Very hard in the commercial market. Sell it to mom ? NO WAY but will barter for monster cookies or rice crispy squares. Pastor ? Sure, at twice the normal rate. Being forgiving is in his job description. Plus he brings home over a million a year in salary & benefits.
      Mikey P and Nate The Great like this.
    18. Tom Forsythe
      Tom Forsythe
      Dec 19, 2006
      193
      Bob, if you working with high end fabrics then a solvent based product makes sense for you. There was a test done a couple of years ago where Larry's solvent based product did not either cause or limit re-soiling, but was neutral. Our solvent based Maxim Fine Fabric causes re-soiling on carpet. This is not an issue for us as we do not recommend application of a solvent on carpet and most are not in the habit of walking on their upholstery. Our solvent based sealers and upholstery protectors use the same base raw material at different solids levels, but one formula can be used on both grout and upholstery.
      I would suggest that you use a water-based protector on carpet. You can select from about 30 in the marketplace, but I have two: Maxim Advanced (stain resistance for nylon and wool) or Advanced Protector with Teflon (water repellency and great oil repellency.)
      Cleanworks likes this.
    19. Bob Pruitt
      Bob Pruitt
      May 22, 2016
      1,969
      earth
      Name:
      Robert Pruitt
      Tom, Many of our high end/ Gaited Community homes here in SW Florida have wool carpets throughout or very large wool rugs throughout. When they call they want all their carpets, upholstery done at the same time and suggesting fabric protection is part of servicing them. I do not want to add water to a job that I have worked so hard to clean and leave as dry as possible.
      I like solvent based protectors for that reason. But not protectors that attract or don't release dirt...that makes no sense.
    20. scottw
      scottw
      Oct 16, 2006
      2,552
      West Jordan, UT
      Name:
      Scott Warrington
      Just for Ofer . I will make this as simple as I can.
      Advanced with Teflon - The best protection against oil. This makes it beneficial for oil loving fibers such as olefin, polyester and triexta (Smartstrand). The oil resistance is also great for upholstery as that is the main concern for a lot of upholstery, hair oils, body oils, etc.
      Also provides better than average protection against water base soils and dry soils. No protection against acid dyes.
      Maxim Advanced - The best protection against acid dyes. Because both nylon and wool are susceptible to acid dyes, this is suggested for nylon and wool carpets. Also offers good protection against oils, very good protection against dry soils and water based spills.
      Maxim Advanced for Upholstery - This is for upholstery, not carpet. This does attract soil on some carpet fibers. It is neutral on upholstery fibers, does not attract soil or repel dry soil. Very good against oils and water. Suggest for high end fabrics, natural fibers.
      Maxim for wool - Similar to Maxim Advanced but more concentrated for the heavier denser pile found in wool rugs.
      Maxim SOS
      - the best protection against acid dyes. No protection against dry soils or oils. Suggested for protecting wool and nylon when a lower cost than Maxim Advanced or Maxim for Wool is desired.
Share This Page
