Hi, I have an older tm that only produces 900 psi max. Is that enough to power a sx 15 or equivalent spinner for tiles or will I get streaking?
My other unit that I am still working on uses a cat 3cp pump with a kero heater. I think I can get about 1200 psi out of that with substantial heat. I was hoping for a sx 15 at least. Is there much difference from the 12 to the 15?
The SX15 has the same water flow as the SX12 but the vacuum design is improved and it will leave the floor much drier, faster.
You will want a brush head with a tm and a squeegee head with most portables
