Judson juice mix ratio
Shane T
Waukesha, WI
Shane Tiegs
I don't use a metering tip in mine so I've been putting in 10oz of O2 juice and filling with soft water. I will increase the amount and add the modifier for heavy soils. They told me this is a little on the light side but I tend to put it down heavier than most others might.
I've put 16oz in the 11qt spraymaster jugs using the yellow tip. I had started using a new sprayer and forgot to look for the tip. My other sprayer had no tip using the same mix. I'm finding it cleans just as well and I'm going through much less juice.
