Saturday night we had a call for a water loss at a 6,000sq/ft home that had a toilet leak on to the marble floors through the ceiling (very ornate) and onto hardwood floors and antique oriental rugs.
Homeowner had taken care of most of the standing water by the time we arrived, the crew did some inspection and triage, setting up drying of the structure and the large rugs.
They returned Sunday and the on call crew and supervisor were there for 5-hours setting up Injectidry's and mats, moving contents so the rugs could be relocated and dried.
Using a thermal camera they could pinpoint what areas needed to be cut out so we could access the ceiling cavity and duct dry air into it.
Some water traveled from the marble floor into the HVAC ducting, the homeowner had cleaned the area up prior to our arrival. Not visible to the naked eye (or dressed eye) was the fact that the water traveled 30-feet in the duct work before leaking out on the other side of the room.
Another good reason a thermal camera is needed when processing multi level water losses. If you're doing water work and don't own a thermal camera, you need to consider the purchase of one.
