MyTee Dry Pulls Yarn and Scrapes Cushions
dantraub
Dan Traub
Has anyone experienced the My Tee Dry Upholstery tool scraping when you pull back? We got a replacement unit from them and it does the same thing. I really like it otherwise but this for me is a deal killer.
GeneMiller
gene miller
I had my sapphire tool do that when a bit of the plastic popped up from scraping something. Silk of course.
Probably a tack strip from using it on stairs.
Gene
Bucey
FFA?
So Mytee doesn't fix the problem? They plug it? Isn't that odd?
Hey Mike, sent ya a PM the other day. Haven't heard back from ya.
KevinL
Kevin Leach
If it's roto molded, they could be working on a fix.
rwcarpet
Robert Hodge
I've changed out the gasket, but can't seem to get the plugs back into proper location. I'm going to try it with out the plugs.
glenboy
GLEN
I just got mine in the mail yesterday should I be returning this tool
I'm not saying the people are lying here, but I would keep it and try it first. On FB, folks who are really straight shooters are saying it's a good tool. It's JMA, so it has to have some merit. Give it a try.
Ed Valentine
Ed Valentine
Way to bad that these things are not ironed out with some type of employed field testing. Wonder What is your opinion?
It and every tool should have be tested by atleast 20 indivduals in twenty different areas and situations
All tools have weaknesses and strengths, tread lightly and heed warnings but don't just abandone the tool or method because 5 people say it is bad as it might just work well for you.
Reactions: Ken Clean
Careful dude cocaine is a very powerful drug. You have me concerned. :winky:
Damn that's (3) I got you twice and piglet once. Easy money! :cool:
Mrice
Mat
I've got one and think it's a very good tool, a big step up from externally jetted tools. The "plugs" are to be used for piping, the tool works best with the plugs out.
Reactions: ruff and Art Kelley
So you need to pull the hard apart to insert the pugs when you want to clean piping?
I used a DM2 today on Velvet...
I need more water than these continuous flow tools put out.
