New VCT should i strip or scrub
Discussion in 'Hard Surface Hub' started by Danv1212, Jul 7, 2018.
  1. Danv1212
    Danv1212
    Jul 7, 2018
    6
    New jersey
    Name:
    Daniel Villavicencio
    Hey guys,
    You’re all great I have used this site before but never posted. I mostly worked with hardwood floors. Got a job coming up for new vct to achieve wet-look. Please help me with best practice guideline. Should i strip first or just scrub with red pad? Is it ill advised to use red pad on a 2000 rpm? Any help will be greatly appreciated.
    Respectfully,
    Dan
  2. Derrick T.
    Derrick T.
    Apr 3, 2017
    2,269
    Reno, Nevada
    Name:
    Derrick Andrew Trulson
    2000 rpm? That's buffer machine.
    Use 175 or autoscrubber if large sqft. I believe it is good to strip it to get the factory finish off and put down new layer of wax coat.
    Let see what other have to say as well..
  3. Derrick T.
    Derrick T.
    Apr 3, 2017
    2,269
    Reno, Nevada
    Name:
    BTW, Welcome !
  4. Danv1212
    Danv1212
    Jul 7, 2018
    6
    New jersey
    Name:
    Thanks for the welcome and the info!!would you recommend the red pad w the 175?
  5. Derrick T.
    Derrick T.
    Apr 3, 2017
    2,269
    Reno, Nevada
    Name:
    Red is buffing pad. Blue and green is scrubbing pads, and brown to black is stripping pads.
    You can get by with blue to scrub and strip.
  6. Danv1212
    Danv1212
    Jul 7, 2018
    6
    New jersey
    Name:
    Thanks Derrick huge help
  7. Small town janitorial
    Feb 23, 2017
    297
    Name:
    Matt Ross
    Newly installed vct should sit for a couple days before you scrub or strip it. I've done both, and you can get good looking floors either way. If the pay is right then go ahead and strip it with a mild stripper dilution and a black pad. If you choose to scrub them to save time or chemicals I'd use a green or blue pad. Not black. I recommend a coat or two of sealer, then wax. Use good wax, dont think you are saving money by getting cheap home depot wax or something like that.
    You cannot use a 2000 rpm machine for any of the above. You need an autoscrubber or 175.
    Danv1212 likes this.
  8. Old Coastie
    5,010
    Heart of Dixie
    Name:
    Bingo on the few days. I’d use a 175 with a brown abrasive pad and water to strip the factory finish (no stripper residue) slurp it very clean and start layering it first N-S, then E-W.
    Something high solids, NOT Zep. Get with your local chemical pimp.
    Don’t buff for a few days.
  9. Mikey P
    72,341
    Name:
    Mike Pay-oh-tay
    Wheres the Janitor?
  10. Lee Stockwell
    FOJL
    14,377
    Benton KY USA
    Name:
    3M SPP with very mild detergent.
    Foam squeegee and extract. Rinse and repeat.
    All of us are janitors...
    Askal and Danv1212 like this.
  11. Derrick T.
    Derrick T.
    Apr 3, 2017
    2,269
    Reno, Nevada
    Name:
    You're
  12. dealtimeman
    10,522
    Fort Worth , Texas
    Name:
    175 Blue pad, if it is dirty the strip it ( cut your dilution ratio way down as you aren’t really emulsifying any real solids just some dirt, glue residue and the bit of factory finish.
    More important to hit with a light acid before and I mean very light, before refinishing as this will allow the floor finish its best result when it comes to self leveling, and the smother/level it goes down the shinier it will be.
  13. Danv1212
    Danv1212
    Jul 7, 2018
    6
    New jersey
    Name:
    Thanks everyone. I am going to use diversey premia ultra high speed as my finish after the blue pad scrubdown. What acid do you recommend before putting the diversey premia down?
  14. dealtimeman
    10,522
    Fort Worth , Texas
    Name:
    Vinegar.
    Askal and Lee Stockwell like this.
  15. Danv1212
    Danv1212
    Jul 7, 2018
    6
    New jersey
    Name:
    Thanks @dealtimeman, im using the diversey by your recommendation from a thread a few years ago as well !
  16. dealtimeman
    10,522
    Fort Worth , Texas
    Name:
    White vinegar half cup (4-5 oz) to a gallon of water.
    Sweep before you lay finish.
  17. Danv1212
    Danv1212
    Jul 7, 2018
    6
    New jersey
    Name:
    Thanks will do
  18. Old Coastie
    5,010
    Heart of Dixie
    Name:
    Michael, I did not know about the vinegar thing. What does it actually do, and could one just add a few drops to a gallon of finish?
  19. Nomad74
    5,373
    Redding
    Name:
    Damon
    I would walk.
  20. Jimmy L
    11,049
    Name:
    Is the % of solids indicative of a superior finish?
    I'd go with betco products myself.
Share This Page
