THANKS GUY'S
Enclosed is more info and pictures of our REACTOR.
Roots Dual Splash 45 or 47. 16 HG lift. 290 or 390 CFM Blowers.
Cat 3CP Pump that only pumps cold water, no recirculated hot water.
Briggs & Stratton 27 HP fuel efficient (especially compared to 40hp + machines), water cooled engine.
Stainless Steel 110 gallon recovery tank.
Standard with a 90 gallon stainless steel supply tank.
Stainless steel low pressure, exhaust gas to cooling water heat exchanger. Bronze, high pressure (1200 PSI), cooling water to wand water heat exchanger. Liquid to liquid heat exchangers are many times more efficient than other type exchangers. Our complete, wand water, heating system consist of only two non-moving metal parts. There are no diverters, sensors, valves, electronics or any other control needed. It is absolutely the simplest and most troublefree heat system ever created. It will maintain over 200 degrees. There is nothing to break or adjust.
Of course it has our trademark, simple design with a few other features like our life-time guaranteed quick couplings.
Go to our website for a list of items that comes with our Pro Package. The Reactor with Pro Package is only $16,990 and compares to and outperforms $23,000 + machines. Plus it is a mechanics dream machine, very easy to service and repair.
