Pressurized drying systems
tres davis
texas
tres
Positive or negative? When to use which one?
What about using 2 systems at same time one positive and one neg?
Curious peoples thoughts and insight for both floors and walls
Onfire_02_01
Minnesota
Jeremy Gray
If I am going to introduce airflow behind walls/ceilings I usually will blow into the space and let the air come out where it may.
tres davis
texas
tres
Used two systems on a two story job where water came under cabinets and tile floor from above. Accessed through ceiling of bottom floor with a push/pull system and a dehu pumping into the push system. Was bone dry in 2 days.
