Put The Industry’s Leading Portable Extractor To Work For You!
All units ranging from 150 to 500 PSI, including models with heat, are CSA-US approved.
40 Liter (10 Gallon) Solution and 40 Liter (10 Gallon) Recovery Capacity: allows for maximum efficiency in time and labor costs, allowing you to work longer without any downtime.
Dual 2-Stage or 3-Stage Vacuum Motors: The Dual 2-stage motor is hooked up in series to give you great airflow and sealed suction and the dual 3-stage gives you maximum lift for more efficient water pick up from your carpets.
Adjustable PSI Pump: Adjustable PSI pump on the 200PSI and 500 PSI models deliver cleaning power and versatility for cleaning nearly any type of carpet or upholstery.
Power Cord: Ninja Classics are outfitted with 25' power cord.
Hinged Design Ensures Easy Maintenance: This innovative design allows access to components making it easy to repair.
Specifications:
http://www.esteam.com
1-800-653-8338
PH: 403-291-7050
Fax: 403-291-0546
Heart of Dixie
What is the name of that portable monstrosity on display in Atlanta? It was very powerful, bare bones on an aluminum hand truck.
