red dye
I use cobb dye remover as of right now, but I've used red 1 by cti and it worked well. Another choice of the boards is the red remover product from vac-away.
KevinL
East Peoria Illinois
Kevin Leach
I'll be the first of many that will say red vanish from vac a way. You beat me Tim, I guess I'll be the second.
Johnny
La-Z-Boy
Johnny
Had three brands on the truck once when I had several red stains on a job. Cobb's worked the best.
Same as above. Larry seems to do the same stain removal like I do; I use a alcohol(1 ounce), 1 Teaspoon Tide sensitive skin, and cold water to blot clean as possible applying all the pressure I can. Then iron on a moist towel on low for about 5 to 15 min.
Tim V. said:
What do you use for kool-aid. Someting that will work everytime.
"Someting that will work everytime."
there is no such thing that works "everytime" on "every" red stain.
(short of LarryB's mention of a knife)
some will disappear completely,
most can be improved using steam/heat, ranging anywhere from a little to almost completely gone
and a few just won't budge
J Scott W
Shelbyville TN
Jeffrey Scott Warrington
Yes, RedZONE is a two-parter. Simply to use. No mixing, no special sprayer. Apply part A, then apply part B.
Will it work every time? Absolutely not. A lot depends on the condition of the carpet - How old? How well protected? What fiber? etc.
It did work better than the #1 product in our industry for red stains.
Scott Warrington
Brian R
Little Elm, TX
Brian Robison
Crap, speaking of which.
I gotta get the hell outa here.
This damn board will take every minute of my day if I let it.
Damn you Mr. Mikey.....Damn you I say. :?
If there is no clue as to what the spot is- I start out with Red One. If I don't get desired results- I then move on to Stain Magic. If even more attention is needed I then move on to Red Relief and steam with at white terry towel.
