speaking of ETMs.....
Discussion in 'the CleAn Room' started by sOOper hero, Jul 8, 2018.
Tags:
  1. sOOper hero
    sOOper hero
    18,892
    Name:
    are there any major manufactures or enterprising outfits doing R&D on lectromounts?
    I don't mean trying to put hi-perf lectrofan vacs in the truck
    But along the lines of how industrial and recreation equipment can effectively/efficiently replace gas engines (forklifts and golf carts come to mind)
    are batteries just too heavy and/or expensive to fit in a van to drive elect motor big enough for blower 'n pump??
    Derrick T. likes this.
  2. Derrick T.
    Derrick T.
    Apr 3, 2017
    2,269
    Reno, Nevada
    Name:
    Derrick Andrew Trulson
    Yeah, mining plants is one. Doubt they use batteries, but giant generators to drive powerful electric motor to run the pumps and blowers.
    Geothermal plants, Casinos, etc have em..
    I guess the efficiency and feasibility is better the larger it gets, but TM size is hard.
  3. Derrick T.
    Derrick T.
    Apr 3, 2017
    2,269
    Reno, Nevada
    Name:
    Maybe Tesla designs could work since some of the cars GVWR is about 7klbs. It could powerful enough run a blower and pump since the torque needed would be lower than what would be needed for driving the car..
  4. Jimmy L
    11,049
    Name:
    Didn't hydramaster have a sort of electroSUX that ran off a very large alternator under the hood?
    Such a small market for anyone to invest time and money to develop.
    SamIam likes this.
  5. sOOper hero
    sOOper hero
    18,892
    Name:
    I get that, D
    Locomotives are electric driven powered by diesel generators.
    There's absolutely no doubt lector motors are available to power any task
    The problem is what it takes to power them
    I have thousands of hours on forklifts and industrial equipment when I worked at the car plant
    Both gas and battery...I know that battery powered stuff can be every bit the equal or better in many applications of such
    I'm thinking it must be a cost and/or weight thing for no battery power'd TM development
  6. Cleanworks
    8,692
    Name:
    Hydrogen fuel cells would work. If you can drive a car with them, you can power a TM.
  7. sOOper hero
    sOOper hero
    18,892
    Name:
    donno
    But that's counter productive if you have to run the VAN engine to power lectric motor
  8. Derrick T.
    Derrick T.
    Apr 3, 2017
    2,269
    Reno, Nevada
    Name:
    Better off driving to charge the batteries utilizing the all 4 wheels like tesla does
    sOOper hero likes this.
  9. Cleanworks
    8,692
    Name:
    with the range that the Tesla has, you could probably run a tm all day. Except for the heat, that will take a lot more amperage.
  10. SamIam
    7,544
    Name:
    It more of a way to use the newer van with out voiding warranties!
    And it’s running a 4.8 blower 3000 rpm.
    You could just put in a slide in, but I’m guessing the push a button start crowd prefer it!
  11. SamIam
    7,544
    Name:
    Cobb was putting something together but that’s like something that never materialized.
  12. Derrick T.
    Derrick T.
    Apr 3, 2017
    2,269
    Reno, Nevada
    Name:
    just use little giant with propane in conjunction with it. No need to waste amps for heat.
  13. Cleanworks
    8,692
    Name:
    Just thinking all electric. Safer and less maintenance. Probably need 10,000 watts to equal a Lg 3 HT.
  14. Derrick T.
    Derrick T.
    Apr 3, 2017
    2,269
    Reno, Nevada
    Name:
    yeah, to maintain 60 mph on tesla car, you need about 17k watts per hour. I figure that to deal with weight issues, LG 3 HT could be used instead and allow all the energy to drive the EM for blower and pump.
    Bill Bruders and Cleanworks like this.
  15. Cleanworks
    8,692
    Name:
    If you're going to use a Lg, might as well use a 4 and be really bad azz.
  16. Jim Williams
    Jim Williams
    908
    Bynum N.C.
    Name:
    Jim Williams
    Maybe Butler could install a machine in a Prius with auto pumpout.
  17. sOOper hero
    sOOper hero
    18,892
    Name:
    that makes more sense to me now
    the direct drive "push button" fanbouys
    how big a generator do they need to shoehorn under the hood for a motor that will drive a big #4 blower @ 3000 rpm?
  18. Cleanworks
    8,692
    Name:
    18,000 watts
  19. Matt Wood
    Matt Wood
    4,635
    Georgia
    Name:
    matt wood
    drive through car washes are all electric. Are those big fan motors that blow off the water on a car big enough to turn a blower?
  20. sOOper hero
    sOOper hero
    18,892
    Name:
    don't think so.
    They need a capacitor to get started, but once spinning they're nothing like the requirements needed for a PD blower under load
    Derrick T. and Matt Wood like this.
Share This Page
