Sqft estimate for a gal. of encap concentrate
Discussion in 'the CleAn Room' started by Sierra Clean Care, Nov 10, 2017.
  1. icleancarpetz
    icleancarpetz
    Mar 7, 2015
    351
    19734
    Name:
    Rafael Samson
    US yes. Dont know about your area.
  2. icleancarpetz
    icleancarpetz
    Mar 7, 2015
    351
    19734
    Name:
    Rafael Samson
    If you say so. My experience says its just the same with same and even better results with a wider range of use.
    But go ahead stick to what works for you. Me, i get the same results and save Benjamin Franklin in my pocket.
    Desk Jockey likes this.
  3. Newman
    Newman
    Aug 1, 2008
    946
    St. Charles, IL USA
    Name:
    Chris Newman
    Damn, I am a heavy user, I need an intervention!
    I assume this formula is for cleaning 300 F2 of already clean carpet without any soil, spots, or stains in it whatsoever?
    Does the formula hold true if the carpet was actually walked on, and maybe even neglected by the Facilities Manager? I know, rare situation.
    Will you get the light foam at a walking pace as applying at this ratio?
  4. steve_64
    7,199
    Had a customer use Mr clean to remove pet odors after I quoted $400. He Read it on Facebook.
    Lee Stockwell and Bruce Humphrey like this.
  5. encapman
    encapman
    1,562
    St Petersburg, FL
    Name:
    Rick Gelinas
    Make a quick wet-pass followed by a slower mostly dry-pass. You can tap the trigger occasionally on the dry pass. You just want the see a very slight even whitening on the dry-pass. You shouldn’t see any whitening on the initial wet-pass.
    If the carpet is more heavily soiled, make an extra dry-pass or two. Making additional dry-passes increases the agitation. You shouldn’t need to add more than a touch of additional detergent as you make your extra dry-passes. With encap, more is not better. Less is best. Even on filthy carpet. Additional agitation will produce better results than adding extra solution/wetness to the carpet.
    Another technique is to apply Encap-Punch as a pre-spray to the heavily soiled sections. It loosens the soil and encapsulates the soil. It’s fully compatible with our encap polymer, and works in tandem with DS2.
    Matt Wood and Desk Jockey like this.
  6. Desk Jockey
    Rico
    56,297
    a planet far far away
    Name:
    Mr Misunderstood
    As long as it works for you that's great.
    I'm not about to risk it to save pennies.
    But thanks anyway appreciate the recommendation! :cool:
  7. Cleanworks
    8,319
    Name:
    Gas is just about there.
  8. Jimmy L
    10,874
    Name:
    Betco's Fibercap MP here.
  9. rider0992
    rider0992
    481
    Red State
    Name:
    . Can’t have too much chems
  10. Sierra Clean Care
    Sierra Clean Care
    Jun 20, 2016
    1,587
    Bc
    Name:
    Jeff T
    Well, job done, it took me and a helper 6 3/4 hrs. I learned a few things today. 1- Encaping is EASY money. 2- using a CRB is NOT the way to encap. 3- I LOVE how quiet it is. 4- I REALLY LOVE not having to deal with hoses. 5- This opens the door to a whole world of possibilities....
    Jeff @ SCC
  11. Derrick T.
    Derrick T.
    Apr 3, 2017
    2,082
    Reno, Nevada
    Name:
    Derrick Andrew Trulson
    Tim OP and simix seems to well too..
  12. encapman
    encapman
    1,562
    St Petersburg, FL
    Name:
    Rick Gelinas
  13. Sierra Clean Care
    Sierra Clean Care
    Jun 20, 2016
    1,587
    Bc
    Name:
    Jeff T
    Matt Wood likes this.
  14. encapman
    encapman
    1,562
    St Petersburg, FL
    Name:
    Rick Gelinas
    Another excellent question.
    First of all, don't flip the pads over. The worn side won't stick as well to the velcro. Run the FiberPlus pads til they wear down to about 1/4" thickness. Then replace. Be careful not to run through them to expose the velcro. You should get about 7,000-10,000 sq ft per installation of pads. That's a pretty fair average. YMV due to of variables - such as coarseness of the carpet, speed you run the Cimex, etc.
    Another question we sometimes hear is about cleaning the FiberPlus pads the end of a job. Don't worry about cleaning them (unless you're doing a rat nasty). The pads get perpetually flushed while you're cleaning. The solution flows through the pads. So they're constantly being rinsed. They'll turn a light gray. But they shouldn't require rinsing after a job (as long as the carpet's in the normal soil range).
  15. Nomad74
    5,010
    Redding
    Name:
    Damon
    4 to 5 gallons. I just did 11k sqf andwent theough 2 gallons. So three at the minimum. I also went heavy is some bad areas so I probably used more than needed. B it man. Want a good payday that was.
  16. Nomad74
    5,010
    Redding
    Name:
    Damon
    Do you have any opinion on the amount of sqft the SuerZorb pads will do? I was curious and pushed them to the limits a few weeks ago. Notmay inchange them out every 300-500 sqft. I ended up pushing itntonabout 1500 sq ft and that thing just kept soaking up.
  17. encapman
    encapman
    1,562
    St Petersburg, FL
    Name:
    Rick Gelinas
    I haven't worked a lot with the Superzorbs. But I can share what I've observed with the MicroBeast bonnets. Microfiber bonnets behave a little different than Superzorbs (but they should be fairly similar). MicroBeast's pull up a good quantity of soil and they rinse easier. Whereas the Superzor's tend to be thirstier. MicroBeast bonnets can go 1,000+ sq ft before changing/flipping the bonnet (on light to medium soiled carpet). For carpet with heavy soil, you'll normally average a few hundred sq ft per side of the bonnet. I'll let someone else comment on the rates for Superzorbs - like I said, my experience cleaning with them is more limited.
  18. Nomad74
    5,010
    Redding
    Name:
    Damon
    I just have one microbeast pad and use it just to scrub. Seems to be good for that. Pretty dang impressed with those SuperZorbs. So are you saying that the Microbeast can also be use as the primary extraction pad as well as a scrubber pad?
  19. encapman
    encapman
    1,562
    St Petersburg, FL
    Name:
    Rick Gelinas
    Yes.
    Nomad74 likes this.
  20. Desk Jockey
    Rico
    56,297
    Name:
    Mr Misunderstood
    We flip them every 400 feet or so.
Share This Page
