The white magic 1200 direct drive. Spill The beans! What do you know about it?
Discussion in 'The Hardware' started by Matt Wood, Apr 11, 2018.
  1. Lee Stockwell
    FOJL
    14,121
    Benton KY USA
    Name:
    5.7 litre Chevy V8, not derated.
  2. Justin Stockwell
    Justin Stockwell
    Mar 18, 2007
    1,215
    I’m gonna quote myself
    “ leave it bone stock and it will have all the heat and vac you will ever need”
    Lee Stockwell and Matt Wood like this.
  3. Justin Stockwell
    Justin Stockwell
    Mar 18, 2007
    1,215
    All the late model (2004 -2010 ) that I have seen have 56 blowers. The 1200 HV is pretty cool. Most have the Vulcan post HX also ( think Butler Max heat and Max vac). The resale plummeted when WM tanked. Or at least I assume it did based on how cheap some sold back in 2014-2016. So you can still find some slamming deals on relatively low hour units.
    Matt Wood likes this.
  4. sOOper hero
    sOOper hero
    18,226
    Name:
    help me with that one, Lee
    It's not the engine ..they're massively OVER powered
    It's cutch/belts/driveline where problems manifest, right???
    AND...what ya'll talking about "derated"???
    What's that mean??
    thanks
  5. Hack Attack
    Hack Attack
    Dec 19, 2017
    512
    N.Z.
    Name:
    Dan
    I was going off lil blurb at bottom but its not the most detailed specs, I'm now assuming its still direct drive not slide in?
    sOOper hero likes this.
  6. Chris A
    Chris A
    Sep 25, 2007
    5,019
    OH
    Name:
    Chris
    I bought a used 2003 four years ago and had it about a year as a backup, half second truck. It had the 56 and Vulcan. I sold it when I bought a new truck 2 years ago and the current owner is still using it daily
  7. bob vawter
    bob vawter
    Sep 15, 2007
    35,045
    La La Land
    Name:
    bob vawter
    2 7/8 OD
    Lee Stockwell likes this.
  8. Jimmy L
    10,673
    Name:
    On that 2000 can you run both blowers at the same time and have them connected ? As in waste tank connected to run in series?
  9. Lee Stockwell
    FOJL
    14,121
    Benton KY USA
    Name:
    They both run in parallel.
    bob vawter likes this.
  10. Jimmy L
    10,673
    Name:
    I'm sure the design was designed to run two wands. Is there more stress on the drive chain running two blowers?
    And what kind and size serpentine/single clutch?
    What is the lift set at?
  11. Lee Stockwell
    FOJL
    14,121
    Benton KY USA
    Name:
    Designed for two entirely independent wands.
    6rib x 56" belt, one Ogura clutch.
    15hg.
  12. Jimmy L
    10,673
    Name:
    My belt is 6 rib 120 inches!
  13. Lee Stockwell
    FOJL
    14,121
    Benton KY USA
    Name:
    White Magic uses a separate belt just for the machine. Driven off a pulley attached to the front crankcase pulley.
    Jimmy L likes this.
  14. steve_64
    6,791
    Want to buy a worn out 2002? I already had to pull the solution line off it for the butler. Not sure if I'll keep it going or not but I will be buying new solution line fotthe butler and put the other back on the WM.
  15. Lee Stockwell
    FOJL
    14,121
    Benton KY USA
    Name:
    Sure
  16. Cleanworks
    7,856
    Name:
    2002 is like new for the old guys.
    Jimmy L and steve_64 like this.
  17. steve_64
    6,791
    I'll get back with ya on that. Still not sure if I'm ready to give it up. I've grown attached to it.
  18. bob vawter
    bob vawter
    Sep 15, 2007
    35,045
    La La Land
    Name:
    bob vawter
    ya i got a little wart on the side of my neck like that!
  19. steve_64
    6,791
    I think it's grown attached to you.
Share This Page
