This might explain why my CRB is making so much noise
Discussion in 'the CleAn Room' started by Nomad74, Jun 7, 2018.
  1. regarossa
    regarossa
    Jun 18, 2010
    86
    Greenville SC
    Name:
    Reg Rogers
    Hey Damon- Is that one of ours or the chinese one?
  2. Nomad74
    5,054
    Redding
    Name:
    Damon
    That is my 5 year old Chinese StrongDry. I didn’t know the difference when i bought it. Now I know better.
    regarossa likes this.
  3. sassyotto
    sassyotto
    Jun 7, 2013
    77
    Wisconsin
    Name:
    Paul
    yep, impact screwdriver did the job no problem. Screws had corroded a little. I don't use the 20 inch much.
    Also agree on the tipping the machine when starting it. It becomes a good habit after awhile.
    Yesterday I had a fellow cleaner text me to ask if he could use one of my Brush Pros because his gear stripped. When I bought my first machine I talked to the owner because I was going to buy an extra set of gears just in case. he told me that I only need the small one because that is the one to go first. I just gave the other cleaner my spare gear and he was good to go!
    regarossa and Old Coastie like this.
  4. regarossa
    regarossa
    Jun 18, 2010
    86
    Greenville SC
    Name:
    Reg Rogers
    We use a product called "Kroil". It seems to loosen those screws up better than anything else. Then put the kung fu grip on it.
    http://www.kanolabs.com
    As far a grease on the gears, a little dab of white lithium grease doesn't hurt each gear while doing maintenance. It typically does more to quiet the gear assembly down just a bit...
    Nomad74 likes this.
Share This Page
