tile and grout
Blue Monarch said:
So curtis,
My eyes must be bad? When the job turns out well, I should assume your juice would do better?
GMAFB
Helluva lot better than Powermax...Ive done side by side.........and thats the bottom line.
Larry
Can I use your liquid brightner in this formula in place of the powdered brightner?
The powders clog the pump up sprayer.
Larry Cobb said:
carpet cleaner,
[quote="carpet cleaner":3egkuh1z]Can you add powdered brightner or liquid brightner to the heavy duty floor stripper?
Sure you can.
Our HD floor stripper ($7.75/gal.) & powder brightener will do a good job of cleaning grout.
The high stripper pH will be irritating to work with.
Larry[/quote:3egkuh1z]
Gary T
TxCon 4800, This Old Grout Deep Clean(not the green version). Both are great high alk cleaners. Pretty much any acid cleaner will do the trick as a last step. I hate Viper Venom, it doesn't clean worth a crap and it's dilution ratios suck. You should never have to go 1:1 to get a moderately soiled floor clean. That's an expensive clean.
Mr.Truckmount
Try our porducts from FloorMaster, we have SurfaceMaster 1 2 3, plus OxyMaster, everybody who uses it love it
T
tokmik
I use prochem powerburst or viper renew acid cleaner for all tile cleanings. To answer your question about sodium percarbonate: prochem has a product for pet stain and odor removal called Odor Rescue which is the same thing as pros choice OSR which is a powdered cleaning agent.
Carpet Cleaning Service
