Travertine cleaner
Discussion in 'Hard Surface Hub' started by Louis, Jun 15, 2018.
  1. Louis
    Louis
    Dec 11, 2006
    1,216
    Modesto, CA
    Name:
    Louis
    So I've been cleaning a lot of travertine lately. I've been using the Stone Pro deep clean. It works good but sometimes just doesn't cut it on some very dirty grout. Also when they have that area rug in the middle of the room and the travertine is all nice and bright it
    just doesn't seem to return back to that.
    What else is out there that I can use that will not take the Shine off their travertine?
    Thank you
  2. Mikey P
    72,342
    Name:
    Mike Pay-oh-tay
    Louis?
    Are you feeling ok?
  3. scottw
    scottw
    Oct 16, 2006
    2,691
    West Jordan, UT
    Name:
    Scott Warrington
    The Stone Pro Deep Clean is a good product. Spinergy Stone Perfect would be an alternative, although I suspect that it may need agitation or dwell time rather than a different chemical.
    Floors can get a layer of oil and grease from the air that originates from cooking or vehicle exhaust or a combination. This gives a shine to the floor but it is not the natural appearance. Any good cleaning would remove this oil sheen. Travertine frequently has a hone or matte finish, but if the customer wants a shine, polishing after cleaning is what is needed. Consider the 1500 grit Spinergy DIP pads.
  4. Louis
    Louis
    Dec 11, 2006
    1,216
    Modesto, CA
    Name:
    Louis
    I worked some nights and it got me screwed up. I thought it didn’t post. So I posted it again.
    Every one in this valley loves shiny. I run into wax all the time.
    If I add 20 vol to deep clean will it take any shine away? I can’t remember the name of the overpriced powdered cleaner that’s out there for travertine. Sometimes the stone just doesn’t bounce back.
    I’m trying to go to stone school soon. Not sure which one yet.
    Mikey P likes this.
  5. Mikey P
    72,342
    Name:
    Mike Pay-oh-tay
    Klenzstone 3...?
    No a powder though
  6. Mikey P
    72,342
    Name:
    Mike Pay-oh-tay
    Stone Pro's Boot Camp does not address cleaning.
  7. Louis
    Louis
    Dec 11, 2006
    1,216
    Modesto, CA
    Name:
    Louis
    I clean stone all the time. I’m just trying to get better results. The crb helps but I’ve had a few I just wasn’t happy with.
    That powdered stuff had some doctor guy in the advertising. You could use it as a booster too. It was like $70 for 6 lb.
  8. Mikey P
    72,342
    Name:
    Mike Pay-oh-tay
    Oxy Blaster from Magic Wand?
  9. clean image
    clean image
    Oct 5, 2012
    670
    Orlando
    Name:
    Carl Maddock
    Agreed, you need to establish if there is a false shine
    And really you need to offer more then just cleaning for SE, FF trav. Refinishing Is often needed for a proper job
    Mikey P likes this.
  10. Louis
    Louis
    Dec 11, 2006
    1,216
    Modesto, CA
    Name:
    Louis
    That’s it Mikey.
  11. Derrick T.
    Derrick T.
    Apr 3, 2017
    2,270
    Reno, Nevada
    Name:
    Derrick Andrew Trulson
    That's good stuff...
  12. ted mcfadden
    ted mcfadden
    Mar 6, 2013
    76
    OC, CA
    Name:
    Ted McFadden
    This was cleaned with Klenzstone in 2010.
    Mikey P likes this.
  13. Jimmy L
    11,049
    Name:
    Should clean that tile tool off once in awhile
    jeremy parr and Mikey P like this.
  14. sincity870
    sincity870
    Dec 21, 2014
    10
    Las Vegas
    Name:
    Jeff
    oxyblaster could dull the stone a bit. I always used Klenzstone3 but you have to be super careful. It will eat the toilet..
  15. jeremy parr
    jeremy parr
    Apr 30, 2018
    113
    Fullerton, Ca
    Name:
    Jeremy Parr
    Right? That is Turbo abuse!
Share This Page
