I have a loss that I've been working on which is a 2 level flood, kitchen/basement plus garage. The garage itself is very cold and the garage door itself does not fully shut, and the area that got wet is also very cold in general.
First, will an etes rise the ambient temp of the combined rec room/garage, the rec room is next to the garage and there's no drywall (now). The temp in both rooms is low, while the rh is not dropping as much as I'd like. Prior to removing the drywall/insulation in both rec room/garage, the rec room itself was already very cold. The current ins is R12, regular pink owens corning (have to check the exact R value).
There's a lgr 2k in rec room, containment barrier, all registers have been shut/tapped over, etc.
Will putting a higher R value insulation on the adjoining walls of garage and rec room keep the heat in more once the repairs commence? It is probably one of the coldest basement I've been in. The basement/rec room is above ground, corner unit townhome.
Thanks,
Bill
Thanks,
Bill
