Wall drying?
Discussion in 'Water, Fire, & Smoke Damage' started by Stevie Bs, Jul 22, 2017.
  1. Stevie Bs
    Stevie Bs
    Jun 10, 2008
    1,405
    Which equipment do you guys use to dry walls, or, do you use dehus only?
  2. Big Jim
    Big Jim
    Nov 3, 2014
    214
    El Dorado Hills California
    Name:
    James Milne
    With respect that's like asking how fast can I go in my car. The answer is that depends, and the same answer for wall drying. The type of water (category), amount of water (class), and the construction and materials involved will determine how to dry and what equipment should be used. Injecti-Dry, Dry Force, and Viking are three wall drying systems that can be used depending on the given situation. Frankly it's to broad a question to answer without more specifics. PM me Stevie if you like to talk about this in more depth.
    dealtimeman, Askal and Stevie Bs like this.
  3. Desk Jockey
    Naughty by Nature
    54,862
    a planet far far away
    Name:
    The One
    Insulated? Turbo vents are the fastest.
    Viking system covers larger areas but lower volume of air delivery. But it does add some resistance heat.
    Injectidry with intercepter and Adaptadry with HEPA scrubbers are used in projects where cavities are questionable but removal was not desired.
  4. Desk Jockey
    Naughty by Nature
    54,862
    Name:
    The One
    We also have Ocidry both for an airmover and for an ETES. It covers large areas but holes are bigger.
    scottw likes this.
  5. Big Jim
    Big Jim
    Nov 3, 2014
    214
    Name:
    James Milne
    No doubt Rich has proper training, different drying systems and understands structural drying. Stevie's question suggests he would benefit most from additional education/training, especially when working with a challenging situation as a wet insulated wall. Other considerations such using positive or negative air, and is there a possibility of asbestos or lead present that needs to be accessed. It's understood he's looking for equipment and system options. If someone doesn't thoroughly understand how and when to use each it's not likely they're going to address the loss properly and could potentially get themselves in real trouble.
    Desk Jockey likes this.
  6. Big Jim
    Big Jim
    Nov 3, 2014
    214
    Name:
    James Milne
    Most of the time I just open the window and send them a $5,000.00 bill.:winky:
  7. Desk Jockey
    Naughty by Nature
    54,862
    Name:
    The One
    IF you can dry them it's "Win, Win" for everyone. Wall is dry in days, home or business owner have the least interruption.
    Cut them out? Structure should still get some drying. Drywall still needs to be put back, taped, sanded, painted. Messy and time consuming. Costs generally go up whenever the claim is open.
    dealtimeman likes this.
  8. Big Jim
    Big Jim
    Nov 3, 2014
    214
    Name:
    James Milne
    Completely agree. So often you see jobs where a contractor or "restorer" unnecessarily cut out drywall simply because they lacked the proper training and or didn't have the right equipment.
    scottw and Desk Jockey like this.
  9. Stevie Bs
    Stevie Bs
    Jun 10, 2008
    1,405
    I have an Injectidry system and a couple of Octidrys. A little cloudy on when to use negative vs positive pressure. Guess I better get the ASD manual out.
  10. Stevie Bs
    Stevie Bs
    Jun 10, 2008
    1,405
    This is what happens when 7 months pass from the time you get your certifications and when you actually start the business. I had a couple of real estate deals screw up my timing.
  11. Desk Jockey
    Naughty by Nature
    54,862
    Name:
    The One
    You can do either and sometimes on difficult to dry trapped areas both is your best method.
    Negative draw is best whenever their is a possibility of microbial growth. I wouldn't suggest drying moldy walls but there are times they find the damage a day or two later. In those case
    Drawing the air is best using the HEPA filter.
  12. Big Jim
    Big Jim
    Nov 3, 2014
    214
    Name:
    James Milne
    If you're just starting out make sure you have the right insurance (contractors pollution liability) coverage, not just general liability. General liability will not cover you if you are sued for improper drying that leads to mold or any other microbial contamination claim. Dave Dybdahl of American Risk Management Resources is an expert in this type of coverage. 608-824-3341
  13. Big Jim
    Big Jim
    Nov 3, 2014
    214
    Name:
    James Milne
    I wish I had a resource like this when I started out. Stevie your best bet is to contact people like Rich or myself when you need some help or feed back on a project. Best of luck.
    Stevie Bs likes this.
  14. Big Jim
    Big Jim
    Nov 3, 2014
    214
    Name:
    James Milne
    It's my understanding that Rich is quite the drying nerd!:rockon:
  15. Desk Jockey
    Naughty by Nature
    54,862
    Name:
    The One
    Jim I was born for it. :winky:
    Seriously for a small service area, we see our fair share.
  16. Stevie Bs
    Stevie Bs
    Jun 10, 2008
    1,405
    I have a CPL policy. Thanks for everything, even the brow beating!
  17. dealtimeman
    9,945
    Fort Worth , Texas
    Name:
    We like all different systems for all the different scenarios we encounter.
    We have 7 injectidry units, 3 drieaz interair and several Viking/air mover with hose units(we almost never use the Viking unit)
    The guys always grab the drieaz units first as they are so light in comparison to the injectidry but does not compete with the injectidry on the power side.
  18. Matt Wood
    Matt Wood
    3,831
    Georgia
    Name:
    matt wood
    Which way is more affordable to the customer/insurance company?
    Taking a razor blade and cutting 2-4ft off the wall and drying with an air mover, and the cost of hiring a sheetrock installer and repainting? Or the Injectidry setup?
  19. dealtimeman
    9,945
    Fort Worth , Texas
    Name:
    Cutting is almost never cheaper if the right conditions are in play.
    Stevie Bs and Matt Wood like this.
  20. Desk Jockey
    Naughty by Nature
    54,862
    Name:
    The One
    You need to add the labor to remove it and dry a day still. Then the mess of sanding and taping. Painting complete walls, wall paper, wainscotting.
    Not to mention the protracted time it takes to get it all back together. Working couples must schedule someone off or risk trusting several trades. Drying is the faster better option provided there is no damage to the drywall.
Share This Page
