Washing white walls - smokers & grease- TSP + will Peroxide help?
Discussion in 'the CleAn Room' started by ruff, Jul 2, 2018.
  1. ruff
    9,332
    San Francisco, CA
    Name:
    Cleaning white walls semi-gloss latex. Dirt and some smoke.
    Will it help to boost the TSP with peroxide?
  2. JohnHawkP
    JohnHawkP
    Nov 20, 2006
    129
    Melbourne
    Name:
    John Paton
    Do a test.
    I have had success with bleach as well.
    ruff likes this.
  3. Andy
    Andy
    Feb 5, 2016
    404
    Michigan
    Name:
    Andrew
    This wall was cleaned with TSP twice. They called, wanted to see what we could do. We used ICWC wall cleaning solution, modernistic has product called RENEW that works the same. I have also had success using Bio-Break with an Oxygen booster in a kitchen ( not sure that you are supposed to breath Bio-Break tho.)
    ruff likes this.
  4. Steve Lawrence
    Steve Lawrence
    Oct 10, 2006
    2,835
    Ann Arbor
    Name:
    Steve Lawrence
    Help with odor, you mean? (I think you've got dirt covered with the TSP.) If it stinks I've heard Tabacattac works good--from Unsmoke. But if there is odor, remember it is everywhere--anything porous sucks up and holds on to stink tenaciously. Probably need ozone to help with that.
    ruff likes this.
  5. sOOper hero
    sOOper hero
    18,892
    Name:
    [​IMG]
    LTA
  6. Blue-Collar Hero
    Blue-Collar Hero
    56,663
    Elysium
    Name:
    Rich
    Ultrapac Renovate works better washing walls than anything we have ever used. I've used stronger chems, Higher PH, boosted chems, ammonia base yet Ultra Pac Renovate out cleans them all. :cool:
    Smoke, soot, nicotine its an amazing product. Very economical too.
    ruff likes this.
  7. Hack Attack
    Hack Attack
    Dec 19, 2017
    924
    N.Z.
    Name:
    Dan
    I've never used this, is it more for removing what you can physically see or removing the odor source that you can't see?
    ruff likes this.
  8. Blue-Collar Hero
    Blue-Collar Hero
    56,663
    Elysium
    Name:
    Rich
    It's for what you can see. Excellent degreaser. I keep some at home to clean up the grill and my hands after cleaning the grill. I also will spray it on my tennis shoes and wash them. They come out like brand new.
    ruff and Hack Attack like this.
  9. Cleanworks
    8,692
    Name:
    You play tennis?
    Blue-Collar Hero likes this.
  10. Jimmy L
    11,049
    Name:
    Whats in that renovate?
  11. Blue-Collar Hero
    Blue-Collar Hero
    56,663
    Elysium
    Name:
    Rich
    Yeah you don't?
    I just have trouble keeping the ball on the court.I get excited and just hit it too hard.
    You'd think I'd learn but nooo same thing every time. Where is the meat powder and that bell? :shifty:
  12. Blue-Collar Hero
    Blue-Collar Hero
    56,663
    Elysium
    Name:
    Rich
    A little bit of Shamwow???
    I'm not sure Jimmy.
  13. Jimmy L
    11,049
    Name:
    SODIUM HYDROXIDE.................LYE
  14. Blue-Collar Hero
    Blue-Collar Hero
    56,663
    Elysium
    Name:
    Rich
    I never lie...I don't always tell the truth but I NEVER lie. We except that one. and that one! :shifty:
    Dude it was good enough for granny mixing it up out by the cement pond, its good enough for Dash Ripprock. :cool:
  15. ruff
    9,332
    San Francisco, CA
    Name:
    Since I posted at the last moment before actually having to do the work, I couldn't try the good suggestions here. I used STPP boosted with Vol 40 (a quart in 5 quart container.)
    Sprayed it on wall and ceiling (fine mist) and wiped with a flat floor mop.
    Worked really nicely.
    Thanks all.
    JohnHawkP likes this.
  16. JohnHawkP
    JohnHawkP
    Nov 20, 2006
    129
    Melbourne
    Name:
    John Paton
  17. JohnHawkP
    JohnHawkP
    Nov 20, 2006
    129
    Melbourne
    Name:
    John Paton
    If it is a hard floor it is quicker and easier to put the product on with a window cleaning lambswool/synthetic washer giving it a good rub as you do. Then a squeegee off. The left over grime can be easily removed with a microfibre cloth.
    Then a quick clean of the hard floor surface
  18. Mama Fen
    Mama Fen
    Jun 20, 2017
    27
    Charlotte NC
    Name:
    Amy Barnes
    Enzymes can help a lot with a tobacco job, since many of the residues left behind by tobacco smoke are lipid-based. Anything that boosts pH into the 12+ range and acts as a saponifier (converting oils into soaps) will also help, which is why ammonia or lye work so well in wall washes.
    Since such a high pH might be dangerous on a hardwood floor, STPP-based detergents and enzymes will be your best resource there.
  19. Blue-Collar Hero
    Blue-Collar Hero
    56,663
    Elysium
    Name:
    Rich
    Never EVER had a problem with Ultrapac Renovate (10.5-11 RTU) on any surface. I'd be more concerned about excessive moisture on wood than the product. We don't use it for floors but any little drips are easily wiped up. 10.5-11 is about like any of the carpet preconditioners.
    Enzymes? Are would you want to fook around with enzymes to wash walls? :eekk:
  20. Goomer
    Goomer
    Feb 9, 2009
    3,342
    Bronx, New York
    Name:
    Frank Mendo
    More likely a layer of nicotine on the surface than organic staining.
    Tsp is probably enough, or some KrudKutter.
    Semi-gloss should clean up easy.
Share This Page
