Waste tank size.
Discussion in 'the CleAn Room' started by steamron, Jun 13, 2017.
  1. carpetcleaner
    carpetcleaner
    Mar 5, 2010
    520
    Gilbert, AZ
    Name:
    Rob Litwin
    Fox TMs by Organic Cleaning Compounds don't really have waste tanks, just a mechanical pump out. In AZ, as long as you filter the water it can be pumped out to flat ground - no washes or rivers.
    Derrick T. likes this.
  2. roro
    roro
    Oct 18, 2006
    583
    Wellington
    Name:
    Ross Craig
    Pretty close to it - ours were built by Duane moon unit - about 10 gal waste tank with continuous discharge -belt driven pedestal trash pump.
    roro
  3. steve_64
    7,016
    So size doesn't matter? Who knew.
  4. sOOper hero
    sOOper hero
    18,433
    Name:
    most anyone with a clue could determine for themselves
    if you have a 60, 75, 100+ gal waste tank, tell me if you can tell any practical difference from an empty tank at start up to a near full one at end of job
    I can't with a 110 gal tank, 45 blower @ 3200 rpm/14" lift
    it ain't rocket science to determine this stuff for yourself , kiddies
    Matt Wood, Ron K and hogjowl like this.
  5. Ron K
    Ron K
    Jan 3, 2009
    1,847
    Could you post a picture? Or contact info. Oops saw the "were"...Larrry C.???
  6. Cleanworks
    8,108
    Name:
    The Big Red I used to work with had about 12 gallon waste tank with a Jabsco transfer pump. #5 blower could suck your underwear off through your pants.
  7. dealtimeman
    10,435
    Fort Worth , Texas
    Name:
    Yes it matters can most tell the difference , no.
    I believe Vacuum, is as we are discussing here can be seen or viewed as momentary yet constant stored energy Potential as long as the machine is running,
Share This Page
