With the thermoplastic or parflex hose, should I increase the flow on my wand?
Discussion in 'The Hardware' started by Matt Wood, Mar 27, 2018.
  1. Matt Wood
    Matt Wood
    4,199
    Georgia
    Name:
    matt wood
    Is there any other guys out there with cobb's thermoplastic hose using a pmf v800? If so, are you feeling the same problem in the trigger?
  2. KevinD
    KevinD
    Nov 23, 2006
    1,687
    Binghamton,New York
    Name:
    Kevin Dumas
    So change the junky valve out.
    Doubt it has anything to do with the hose.
  3. Matt Wood
    Matt Wood
    4,199
    Georgia
    Name:
    matt wood
    I'm a little frustrated, because I paid $100 for the "junky" v800 valve in the video.
  4. Hack Attack
    Hack Attack
    Dec 19, 2017
    512
    N.Z.
    Name:
    Dan
    I cant see it being anything to do with the actual hose either
  5. Desk Jockey
    55,828
    a planet far far away
    Name:
    Mr Misunderstood
    It's the hose. Your machine gets too hot.
    Wasn't it fine when you switched hoses?
  6. Hack Attack
    Hack Attack
    Dec 19, 2017
    512
    N.Z.
    Name:
    Dan
    the fittings on the hose I could understand
    but a hose isnt going to make a machine run hotter, the water starts cooling as soon as it leaves the heat exchanger
    I run an extra 50 ft of hose on my fuel burner in summertime to drop the temp of hose inside the house
  7. Desk Jockey
    55,828
    Name:
    Mr Misunderstood
    We had some rubber hose we cooked by not pulling it all off the spool. It never had the flow comparable diameter hose did. It became such a pita finally gave up on it. Bits of rubber would clog the screens as it deteriorated.
  8. Hack Attack
    Hack Attack
    Dec 19, 2017
    512
    N.Z.
    Name:
    Dan
    haha yep been there, thought the van was on fire! :eekk: no just melted the hose and spraying hotwater everywhere
    I dont run anywhere near as hot as I used to..
    in so many ways
    Lee Stockwell and Desk Jockey like this.
  9. Matt Wood
    Matt Wood
    4,199
    Georgia
    Name:
    matt wood
    I thought it was fine, but the second video was at the beginning of the job when the water wasn't very hot. So temperature isn't the problem. That's why I'm so confused here. It doesn't make any sense why the trigger valve is the culprit, but from the testing today, it is.
    Desk Jockey likes this.
  10. Hack Attack
    Hack Attack
    Dec 19, 2017
    512
    N.Z.
    Name:
    Dan
    occam's razor
  11. Lee Stockwell
    FOJL
    14,121
    Benton KY USA
    Name:
    Steel braided hose doesn't "give" like thermoplastic, thus gives crisp ON or OFF action.
    Thermoplastic has a slight "balloon" effect that increases the action you noted at the beginning of this thread.
    Add to that the fact that you likely DO have more retained heat at the trigger.
    Matt Wood likes this.
  12. Lee Stockwell
    FOJL
    14,121
    Benton KY USA
    Name:
    Roughly: kiss
  13. Matt Wood
    Matt Wood
    4,199
    Georgia
    Name:
    matt wood
    Yeah, I’m still loving this hose. The benefits outweigh the negatives. I loved my v800, but I don’t mind switching over to a soft touch.
  14. Larry Cobb
    5,791
    Dallas, Texas USA
    Name:
    Matt;
    It looks like a restriction in the wand.
    Could be a filter or a clog in a line.
  15. sOOper hero
    sOOper hero
    18,226
    Name:
    you don't like Westpac's soft touch??
    Its a great valve ..at 1/3rd the price
    ..L.T.A/
    Radar Foster and Matt Wood like this.
  16. Matt Wood
    Matt Wood
    4,199
    Georgia
    Name:
    matt wood
    Nope, the soft touch valve fixed the problem. I had a clean filter, clean jets, new qd's. The V800 was the culprit. Because I tried to rebuild my old v800 before I bought a new one. So 2 different v800's told me that they don't like that hose.
    I'm kinda glad this happened anyway. I used my v800 forever ago, and the soft touch is way more friendly and cheaper. I still love the thermoplastic hose. I'm glad this was the only problem
  17. Desk Jockey
    55,828
    Name:
    Mr Misunderstood
    Its the hose. Is there warranty? :winky:
    Radar Foster likes this.
  18. Matt Wood
    Matt Wood
    4,199
    Georgia
    Name:
    matt wood
    Who on here uses a buffer hose to hook up their par Flex or OEM thermoplastic hose? Meaning who doesn't hook up the hose directly to the truckmount?
  19. jcooper
    jcooper
    2,821
    IL
    Name:
    Jerry Cooper
    Yes, everyone should use a "buffer" or starter hose. For us/me I run 50' of steel braid then my parker. I've been told not to hook the thermoplastic directly to the truck. Too much heat. Even 25' would probably be fine. Now, if it's super short hose run occasional(once in a while) I will hook up right to the machine, just not often.
    I've had my parker hose for over 5-6 years.
Share This Page
