- Oct 7, 2006
- 10,877
- Name
- Jim Martin
ALWAYS..keep a spare &%^$#! float assembly for your water box in your truck.........
I flooded mine today too.I plan on swinging in and picking up a spare float assembly and have it on the truck...I know this will happen again...
Ruff Hewn said:I plan on swinging in and picking up a spare float assembly and have it on the truck...I know this will happen again...
not as long as you have the extra float on the truck...Murphy's law![]()
..isen't that the truth....I am sure I still have a few Vortex/UD parts that I got for back up that have not been farmed out yet.......
Jay Hawk said:We were good today, yesterday was a pain. Had three trucks down, a Butler with a short that makes the door locks and brakes lights go off and on everytime you stepped on the brakes. Another that had Carb problems and had trouble running, we sent another truck and when they went to start the unit the battery was dead. Someone left the key on, no big deal just jump it but neither truck had cables. The crew leader went to NAPA, jumped it got back to cleaning and no water pressure. The fitting at the water vessel broke and flooded the truck, but he connected direct and finished the job.
Got one truck back but still have a Butler at the auto electric shop and one at the distributor. Anyone making any money?![]()
Larry Cobb said:Jim;
After testing many . . .
this is the one we use on our TM's :
Installed, arm is straight out from valve.
It has a nylon float and durable seal.
Larry
Jim Martin said:http://interlinksupply.com/index.html?i ... P15-808110[/url] its expensive as hell but it will never break and the rebuild part is cheap, $6.20 to be exact. this same valve has also lasted 10 years on my water tank with water beating and sloshing into it when the tank is partially full, on that one the float arm can drop too low and get stuck. I put some zip ties on it to limit travel to about 6" up and down and never have and issue with it. so far in all the pochems I have ran that has this type of valve never needed to replace any of them.
Jim Martin said:I had Niagara falls coming out of the truck by the time I noticed it....
right after I had set up and put pre-spray down on my first job...I went out to the truck and everything in the back was floating....what a mess...
Jim Bethel said:[quote="Jim Martin":20nc1zf6]I had Niagara falls coming out of the truck by the time I noticed it....
steve g said:http://interlinksupply.com/index.html?i ... P15-808110[/url] its expensive as hell but it will never break and the rebuild part is cheap, $6.20 to be exact. this same valve has also lasted 10 years on my water tank with water beating and sloshing into it when the tank is partially full, on that one the float arm can drop too low and get stuck. I put some zip ties on it to limit travel to about 6" up and down and never have and issue with it. so far in all the pochems I have ran that has this type of valve never needed to replace any of them.[/quote:joth0jlm]
Mine started sticking and I found the exact same unit at ACE Hardware for 16.00 = tax.
GeneMiller said:Mine broke when it was fairly new and here is how i fixed it. 9000 hrs later no problems.
gene
