Prochem vs Magic Wand
I've been waiting for my rental move out season to start so I cold sample two products side by side. Here are the two products.
I tested the side by side on a job today and they both did very well. I couldn't tell much difference between the two.
So, I could go with either product and be fine, performance wise. The problem was in the packaging.
The Prochem product was liquid and the recommended mix was 16 oz per gallon. The Magic Wand product was powder and mixed at 1 oz per gallon.
Now which would YOU buy?
I don't understand why some mfgs don't consentrate their products more?
Reactions: Art Kelley
I'm not certain on the Prochem product. I won it at auction.
The Magic Wand product is packaged in a 30 lb. pail that I paid $206 for. 30 lbs is 480 ozs. So it's 43 cents per ounce or 43 cents per RTU gallon.
I'll have to look up the Prochem product.
Ok, looked it up at Jon-Don. Price per gallon, including shipping, is going to be right around $21 per gallon. $21/128 = 16 cents per oz. 16 ozs per gallon would be $2.56 per ready to use gallon.
Goomer
Frank Mendo
A 175 scrub can make most any product shine.
Which product cleans better without a scrubbin?
At $2.56 per RTU gallon, the Prochem product should get the rotary off the van for me and scrub it itself.
Not sure about your question though. I haven't used the Prochem without scrubbing yet. I HAVE used Grease Eater on several jobs without scrubbing and it does quite well.
On average, prescrubbing adds 20% to a two man job and 50% to a one man job.
Ray Burnfield
Ray Burnfield
I've always scrubbed pre-spray regardless of the machine being used.
I guess it's like vacuuming.
1st thing you learn to do but don't do it.
you know you got a good one when you have to pre scrub before rotary extracting...
Not often, but some times...
we see more flat out pig pens than your list..
a family of four or five slobs, no vacuum and no pride can really do a rug in.
and how much do you apply to say, 500 feet of normally soiled, nylon pile?
That is one thing I don't track, but I'd say X of a gallon. Oops, I'm editing that answer because I forget sometimes that my Multi-Sprayer jug us 2 gallons. So, about a gallon.
Willy P
Willy P
No scrub porty cleaned. I would have scrubbed it, but I pulled the scrubber off for some reason.
Ultrachem Clean, peroxide and procyon rinse. None of the above. I love dirty ones.
is that a blanket or real loose carpet?
Ray Burnfield
Ray Burnfield
I really don't know how a pre-spray could work to it's best ability without agitation and dwell time
most repeat carpet don't need the "best ability" of any prespray...
just some lubricity and it's deo ability.
Goomer
Frank Mendo
The time it takes to scrub will also double as a dwell period.
Best of both worlds.
