Pro1200SE heat - for people who want to know.
What percentage of time/labor and chemical savings are you predicting?
Marcus
Scott
How much water. Flow or how many total jets 10-12 flow????
And will it hold the heat for at least 2-3 minutes with trigger pulled??
Like to see test on medium and high
And what are the rpms for medium vs high
Cap
Awesome, but proves nothing. put a temp gauge on at 100' and then show us. Manufacturers put the temp sensors in convenient places to show the most possible heat.
Actually it proves his temp guage works in the right positions. He's getting good temp control.
The test at connections prove with a 12 flow wand he's getting what the butler got 195 Atw.
To say it proves nothing is a little off.
For a Pto it's getting slide in heat. That's impressive.
Maybe not the heat your used to but get the 870 it blew the El Diablo out of the water and that about the same as what you get.
One other thought they put the temp switch and control at the hottest point to control the heat, not sure if SS has a 285 heat shut off or not just another safety measure if things get out of control.
But they probably don't want it going over 240 to protect the machine.
You technodweebs crack me up. Heat heat heat...you can't wash your butt without heat.
I clean with cold water regularly and it looks better than anything your flame thrower can ever deliver!
Much better
!!! :cool:
Reactions: Art Kelley
Dan, you're spoiling my fun. I'm just trying to give them an uncomfortable feeling in their shorts. :icon_twisted:
Serious about the cold water though. Cimex and encap solution and some of y'all will be in tears. (one trick ponies!) :biggrin:
It won't matter how hot your water is, the encap side will look better.
An that's the REAL deal...doe! :winky:
Cimex cleans better with hot.
Lee we will get hot water right out of the Butlers convenience hose and I cannot see any difference in cleaning vs cold water. Whenever we have left over Encap solution we will pour it out into 5-gallon containers and still use it if we have a job later in the week.
I've cleaned side by side using HWE and boiling hot lava water and the encap side "looked" cleaner & brighter.
I know it couldn't be cleaner since the was no removal of the soil load but it damn sure looked better. Not as good, not slightly better, but much better. :eekk: :neutral: :dejection:
:biggrin:
Reactions: Russ T.
Heat is a factor, but not the major factor it used to be. My Vortex days cured me of that.
Anything over 200 at the machine is fine with me. As long as it is continuous and dependable.
So far, the Cleanco is giving me 210-220 all day long at 12 flow.
I'll take that any day.
I reread what you wrote Mike your right the temp guage ATM ISNT WHAT YOU GET ATW.
During the months of June and July we get our fair share of those jobs. Our rental market turns over every year during those months (military) and so we get our share of those jobs. It will be interesting to see how the Cleanco stacks up beside the Chief II next year, but judging by what I am seeing right now, I don't anticipate any difference.
Richard, I did not realize you were a "boutique" cleaner. To good to get dirty;)
Ron I was born in dirt. Dirt is my middle name. I play in dirt. I am dirty. I lubb dirt. But yes you are right we don't clean "shit holes".
We clean "clean" carpet, which isn't as easy as it sounds. Improving clean carpet can be difficult but fortunately it pays better than cleaning "shit holes".
I know it makes little sense but the harder work pays less than the easier work. I don't make the rules, I just play by them :winky:
My Brother Dave got his high heat Butler from me a month ago....
We pick on him now getting burned, or getting the "Mark of the Beast" and how much it hurts to just take the connectors off sometimes....:lol:
We're all a bunch of Sally's some days ....and then the new burn marks on us....:errf:
Did I mention how we are becoming older and a bunch of Sally's ?! :lol:
