MikeysBoard
- Sep 4, 2014
- 87
- Name
- Bob Long
Description:
Quite possibly THE BEST back up for one truck owner operators!
Works great on upholstery and incredible with a Rotovac 360 i or XL*
Comes with 50' solution line and 50' drain hose w/faucet adapter. Non stop high flow cleaning. 15 gallon extractor. Auto pump out at 6 gpm. No defoamer needed with the air/water separation system. High velocity vacuum motors. Small size to fit into any vehicle.
Factory demo, 1 year warranty. Essentially brand new. Might have some scuffs on the tank and wheels but otherwise looks new
$2100 retail
Auction starts at $1200 and includes FREE shipping
Today, extractors are heavy and bulky, weighing close to 100lbs requiring a large vehicle for transportation. In addition, they must be filled and emptied continuously throughout the entire job; a process known as the "Bucket Brigade".
The new CFX 15 is compact, weighing only 39lbs. It can be carried in one hand or transported in any size vehicle. The CFX 15 utilizes Continuous Flow Extraction for nonstop cleaning. An easy direct faucet hook up adapter provides an unlimited clean water supply. As the dirty waste water enters the recovery tank it is automatically pumped out into any toilet or drain. With the CFX 15 you can perform High Flow non-stop extraction cleaning and say goodbye to the "Bucket Brigade” forever.
Bid Now at Cleaning Classifieds
** You must create an account in order to bid on items. Your Mikey's Board credentials will not work. Click the following link to create your account: Register **
$2100 retail
- Non-Stop High Flow Cleaning
- Auto pump out at 2.6 GPM
- 15 Gallon Tank
- Patent pending air/water separation system, no defoamer needed
- Dual 2 or 3 stage high velocity vac motors 200 CFM
- Saves Time & Labor
- Quick and easy dump valve
- Only 39 lbs, fits in any car!
