It's Alive! New Saiger's Webstore, New Saiger's Sauce 1
Grand Rapids, MN
It's alive!
Saiger's webstore just opened!
Still detailing.... but up and running.
New Saiger's Sauce 1 just going to production and ready in a couple weeks.
Come see the New Sauce at the Mikey's Fest in Nashville TN!
https://www.saigers.com/supplies
Congratulations on your chemical line up. I look forward to using your special sauce that I hear so much about. I need to use up a ton of my chems before I purchase any more, so give me a few months and I'll order a case of it.
Reactions: Mark Saiger
As I told Mr Happy....his world is about to change. He is now the Goliath and his haters are the Davey.
I wish him the best of luck in this en-devour.
Next thing he needs to do is add a 1-800-TLK SHOP link. Enter your credit card to talk to Mark about O rings, VJet sizes, zipper techniques and righty tighty lefty loosy teflon tape wrapping facts for $2.99 per minute.
Grand Rapids, MN
So is the Saiger Sauce mix the same as the Saiger special sauce mix just no mixing required?/ or is it better. Tell us more about it please.
Brand new coming out in couple weeks....Saiger's Sauce 1 but other Starter packs are available if you want to try the other products in smaller sizes vs buying full case lots of the other Saiger Favorites (called Saiger Sauce Mixes)
The new product is Powdered prespray with typical mixing ratios. It works very well as stand alone....
I did discover that added a Booster Powder Peroxide when appropriate and our soy based G-Force Booster (which is now Lemon Scent) can also give a good kick on the greasy stuff.
Here is the product description and directions (and do have to give some credit to Mikey P for description editing :) ) :
Saiger’s Sauce 1
The Power of the Blue!
“Bring on the Blue Bullet!”
Enviro Safe – Non Toxic
Description
From 4 generations of Saiger family cleaners, we bring you “Saiger Sauce 1”. The highest quality, very economical, multi use prespray you can buy.
A unique product created by 50 plus years of cleaning experience and passion, astute observation and testing in real world cleaning situations. A “one product” to help with most of your professional cleaning needs on carpet, tile and grout, synthetic rugs and garage floors, stone patios etc..
Gentle enough to be your everyday pre spray or your Blue Bullet on greasy commercial work.
For best, long lasting results, we recommend the use of an extraction agent in your cleaning system such as Harvard Heavy Duty Extraction Rinse (still producing for Neutral 7 Ph range) or other Harvard Chemical Research Rinsing agents. www.hcronline.com
Slight Fresh Lemon Scent.
No NTA, D-Limonene, Butyl’s or other harmful solvents.
Directions and Suggested use:
Be sure to mix with warm to hot and preferably “soft” water. Normal soiling with your best repeat clients will require far less product usage. We recommend experimenting to find what works best for you
Product is quick dissolving in hot water, another time saver! Use the supplied measuring cup and don’t store more than you need on your (hot) truck.
-Pump up or Electric Sprayer – 1 scoop (2 ounces) Saiger Sauce One to 1.5 Scoops (3 Ounces) of “Saiger Sauce 1” per Gallon of warm to hot water. Very severe jobs may require up to 3 ounces – 4 ounces per gallon. Test first so you don’t waste this valuable solution.
-Hydro Force Type Injection Sprayer – Dilute 8 – 9 scoops “Saiger Sauce 1” (16-18 ounces) per 5 quart container with warm to hot water, and meter at 8:1 setting. (If not using a metering tip, it is typically at 4:1 setting: THEN dilute only 4-5 scoops which is 8-10 ounces of “Saiger Sauce 1”).
With either pre spray method, for the best long lasting results, use an extraction agent such as Harvard Heavy Duty or other Harvard Chemical Research Extraction Rinses.
More Helpful Cleaning tips:
We highly recommend mechanical agitation of some sort in traffic lanes and high usage areas for deeper and quicker results. Do not rely on “wand scrubbing” to break the soil loose. This over wets the carpet and wears out your lower back and shoulders.
Chemical usage suggestions can be far less if you take our advice on the soft water and scrubbing. Trust us, take your time, pre vacuum, wear a big smile, a nice shirt and stand out from your competition with this great product and your passion!
For tile and grout we recommend mopping the product down to avoid splashing. Use the same dilutions as you would with a pump up sprayer and don’t forget to scrub the grout lines.
Thank you for Choosing Saiger’s Sauce 1!
We think you will find this prespray a favorite no matter how you use it
Consider adding Harvard GForce Booster and Booster Powder to your cleaning arsenal for another unbelievable cleaning experience!
Reactions: sealcanvas
FFA
PA
FFA
Its gotta be good, you put your name on it Mark. Ill take 10 pallets worth asap:headbang:
Andy
No Where
Doesn't Matter
When Starbucks started to sell their premium coffee they handed out FREE samples. Just saying
Reactions: FFA
Not to pick on you Andy, but how much money and time on his hands do you think Mark Saiger has?
Are you aware that besides from working 10 hours a day cleaning carpet 6 days a week he has kids, grand kids and a wife?
Marks gets over 20 young carpet cleaners a day calling him for guidance EVERY single DAY. Being the great human that he is, he takes the time to communicate with each and every one of them..
and now because of your (hopefully joking) request, he'll be driving a sample pack over to you somewhere in Michigan on the 4th of July instead of sitting on his pontoon boat drinking Mojitos with his wife..
